No Power ANYWHERE!!!
did something really dumb today puttin sohc vtec in my hatch.. connected a wrogn wire to the starter.. tried to start it turned over then stopped.. ground on the battery melted then no power.. checked all fuses.. al grounds.. all everything and cant figure it out.. SEARCHED and came up with nothing so hopefully someone can help me out..
i connected the ground that goes to the thermostat housing to the starter.. cause the harness was off.. and i didnt relize it.. and i did check all the eunderhood fuses and relays.. all good
ok. no more problem.. before when i first tried to fir it.. the positive running to the start bolted up and then leaned up against the starter.. so it burnt a whole in the rubber and like welded itsef to the starter.. causing the dead cell in the battery like some of you said.. and major sparks connecting the battery.. so not everything all good.. car was running fine.. took it for a test drive and the clutch gave out when i was showin the dude who wanted to buy it.. worst timing but **** happens.. now i need a new sohc clutch and put it in by tomorrow.. which means more work that i dont feel like doin..
cvcrcer
Jul 6, 2005 01:33 PM
EG6owner-T
Jan 4, 2005 03:41 PM
