GSR water pump and timing belt on a B16
I was going to pick up a GSR water pump and timing belt for my B16 because i heard if you use a GSR water pump you need to use the timing belt for the GSR as well. I want to verify this. I also heard that the GSR water pump his better then the B16's that is why i'm considering it. This is for an engine that will make over 400HP.
hitvtecgetloud09
14
Jul 12, 2005 06:43 AM
hitvtecgetloud09
Jul 10, 2005 05:07 PM
