what timing belt and water pump for a CRVtec motor?
Who is Mr Robot?
Re: what timing belt and water pump for a CRVtec motor? (11secEk)
what head are you using? you use the timing belt for the water pump you are using, i think its also head dependent
Re: what timing belt and water pump for a CRVtec motor? (wantboost)
ive setup two CRVtecs before and i cant remember... i useing a gsr head. i think we went with a gsr belt and b16 pump, but i cant remember and the car got sold to someone i dont know...
if you are using the GSR head with GSR water pump then use GSR timing belt
if you use ls water pump 21T vs the 22T pump GSR then you need the other belt
Re: what timing belt and water pump for a CRVtec motor? (b18bturbo)
Cool, thanx for the info guys i guess ill try that... i have a ls, b16, gsr and crv pump on hand to try... but thanx guys
