Idea for 3" floating exhaust flange - Good or bad?
Old Apr 28, 2006 | 07:49 PM
DJ Gurgla GSR's Avatar
Default Idea for 3" floating exhaust flange - Good or bad?
I just rec'd a custom downpipe for my turbo kit. It has a 3 bolt 3" flange welded on the end. I also have a thermal 3" catback exhaust with the same type of flange already welded on.
Just ordered a 3" universal magnaflow cat (no flanges)
I want this to be fully bolt up with as little fabrication work as possible
I saw this product in the summit catalog
http://store.summitracing.com/...w=sku
My idea is to measure the length i need, then have these welded on each end of the cat, leaving the triangle flange 'floating' so it can bolt up easily. I would use the gaskets also.
Will this work? Will this last? Will it leak? Is this a good idea or a bad one i had while smoking and thumbing thru the summit catalog?
thanks...
Old Apr 29, 2006 | 12:52 PM
beepy's Avatar
Default Re: Idea for 3" floating exhaust flange - Good or bad? (DJ Gurgla GSR)
Just use a gasket. These are the type of flanges that I have used on every domestic car I have owned.
bump for some opinions
Old Apr 29, 2006 | 01:40 PM
TeamNextGenChris's Avatar
no reason you can't have flanges welded on each end of the cat to mate up to the downpipe and exhaust.
the idea you have should work i guess,the only concern would be leakage.
also,make sure there's a flexpipe somewhere in there between the downpipe and cat.
Chris
Old Apr 29, 2006 | 07:03 PM
AspectIndustries's Avatar
Default Re: Idea for 3" floating exhaust flange - Good or bad? (TeamNextGenChris)
Ive used those before, and they actually hold up nicely. Seals perfect, but make sure you put that gasket in between.
Old Apr 29, 2006 | 07:04 PM
I cant weld. so to weld the flanges on the cat and getting it exact requires me driving my car to a shop, getting it on a lift etc. All cost money and i have no one reputable to do it.
Theres a flex sectioi welded into the downpipe.
so the consensus is that i can do this? Just make sure i use gaskets?
Old Apr 29, 2006 | 07:18 PM
Wells,
Have you notice both ends of the Magnaflow Cat is a little flared?
Meaning, you can slip in 3inch pipings into it. Will save you time and money. -=P If you cant weld, then use exhaust clamps in the mean time.
Old Apr 30, 2006 | 03:29 PM
Default Re: Idea for 3" floating exhaust flange - Good or bad? (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Wells,
Meaning, you can slip in 3inch pipings into it. Will save you time and money. -=P If you cant weld, then use exhaust clamps in the mean time.</TD></TR></TABLE>
yeah,all Magnaflow products are flared to slip fit.get you some clamps and you're golden.
Chris
Gdub00lude
Feb 2, 2006 12:55 PM
mrbsponge
Mar 17, 2005 07:39 PM
Rory Breaker
Jun 25, 2004 08:40 AM
speedymon
Oct 17, 2003 02:04 AM
Comtechgsr2000s
Nov 25, 2001 07:37 PM
