vtec engagement problem
Old Apr 24, 2006 | 02:41 PM
pregosAMPA's Avatar
Default vtec engagement problem
I GOT A 99 GSR ON A 93 EG MY VTEC ENGAGES 1ST 2ND GOOD THEN ON THIRD IT HITS AND AFTER LIKE 7K RPM IT GOES AWAY THAN THE CHECK ENGINE GOES ON AND THROWS CODE # 22 VTEC PRESSURE SWITCH THAN IF I TURN THE ENGINE OFF AND ON IT WORKS FINE AGAIN IF I DONT PUSH 1ST GEAR AND 2ND THAN PUT IT IN THIRD THE VTEC KICK IN ALL THE WAY TO 8200 RPM THAN AFTER I DROOPED TO 4TH GEAR IT IS BACK ON AGAIN,,, I HAVE A P06 CHIPPED WITH CROME I ALLREADY TRIED A P28 AND SAME **** HAPPENS SO I ALL READY CANCEL OUT THE ECU... I WAS WONDERIN U KNOW THE OIL PRESSURE WITH UNDER THE VTEC SOLENOID ? SHOULD I GET A 5 VOLT REFERENCE ON ONE SIDE AND GROUND ON THE OTHER? AND DO U KNOW WHAT PIN I THE COPUTER THAT 5 VOLT REFERENCE COME FROMM PLEASE HELP OUT I HATE TAKING PEOPLE OFF THE LINE THAT SMOKED IN THE LONG RUN
Kova23
Engine Management and Tuning
Oct 15, 2012 11:25 AM
HondacivDX
Feb 19, 2012 06:52 PM
pokmijn
Dec 27, 2007 07:27 AM
andysila
11
Nov 24, 2005 04:47 PM
boosted k20
Jul 21, 2005 07:15 PM
