final drive compatibility
Old Apr 22, 2006 | 06:15 AM
cbmprelude's Avatar
* B A N N E D *
Default final drive compatibility
can the 3.25 final drive from a crx hf fit in a hydro ek cx tranny? I know the fd is lower and was thinking about it to conserve fuel.
Modified by cbmprelude at 6:12 PM 4/22/2006
Old Apr 22, 2006 | 09:12 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: final drive compatibility (cbmprelude)
bump
Old Apr 22, 2006 | 10:34 AM
Syndacate's Avatar
I'm pretty sure it can't, but I might be wrong..don't take my word on it :-\
Old Apr 22, 2006 | 04:03 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Syndacate)
Does it make a difference that the final gear itself is a much smaller dimater (I'm assuming)
Old Apr 23, 2006 | 09:23 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (cbmprelude)
should be same 3.25 FD, the ring gears are the same, but the countershafts are different.
Old Apr 23, 2006 | 09:38 AM
schardbody's Avatar
yeah, even if it fit it wouldnt make a differance, they got the same FD.
Old Apr 23, 2006 | 10:16 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: (schardbody)
ohh really, I thought the 3.7 final drive came standard in the ek cx tranny not the 3.25
Old Apr 23, 2006 | 10:19 AM
schardbody's Avatar
nope, 3.25, 3.7 is the dx/lx hx/cx is 3.25
Old Apr 23, 2006 | 10:28 AM
cbmprelude's Avatar
* B A N N E D *
ohh ok thanks the website I had looked at published it as the 3.7 Is there any problem with upgraded to say the 4.2 in the ex? Will there be space issues or will I have to ground down the inside of the tranny?
Old Apr 23, 2006 | 03:42 PM
cbmprelude's Avatar
* B A N N E D *
Bense's thread
https://honda-tech.com/zerothread?id=1593351
claims my cx has a 3.7 with the eg has a 3.25
Old Apr 23, 2006 | 04:02 PM
cbmprelude's Avatar
* B A N N E D *
not trying to be an ***, but now I am very curious
Old Apr 23, 2006 | 04:07 PM
schardbody's Avatar
everything i have ever read says cx/vx is 3.25 FD.
Old Apr 23, 2006 | 04:17 PM
cbmprelude's Avatar
* B A N N E D *
looks like Im gonna have to find out and report back
Old Apr 23, 2006 | 04:32 PM
Bense's Avatar
67/18 when I counted my 96 cx final drive
cx shares the same transmission as the same year vtec-e model.
92-95 cx / vx is the same
96-00 cx / hx is the same
Old Apr 23, 2006 | 04:41 PM
Bense's Avatar
Default Re: (Bense)
3.25 is found in some crx hf's But it's pointless to try to get that to work in a hydro case. Because by the time that you do all that, you could have bought either a vx/cx final drive from either bone or me for very cheap.
I think I have two of these things. Wait, I am getting a vx tranny tonight for free, so I have three of these things.
Not worth putting a 3.25 in any transmission, because it will be easier to find one of those vx boat anchors that honda calls a transmission.
Because of the confusion with cx/vx and cx/hx transmissions I always try to refer to the 92-95 cx as a vx transmission. While refering to a 96-00 cx as a hx transmission.
92-95 vx gears are far apart from each other with the 3.25 final drive
remember, these cars had 13s on them. And didn't make any power past 4k rpm.
96-00 hx gears are the same as 96-00 dx gears, but with the 3.7222 final drive instead of a 4.058
vx = (65/20) 3.25
hx = (67/18) 3.722222222222222222222222222222222222222222222222 2222222222222222222
dx = (69/17) 4.0588235294117647058823529411765
ex = (68/16) 4.25
Bense's Avatar
Default Re: (Bense)
oh yeah, and all dx (92-00) have 4.058
1909th post, like my 2nd gear ratio. (1.909)
Old Apr 23, 2006 | 04:50 PM
schardbody's Avatar
so the hx tranny does have 3.70 FD???? im still lost you bastard.
Old Apr 23, 2006 | 10:26 PM
cbmprelude's Avatar
* B A N N E D *
I just purchased a cx eg tranny from a great fellow ht-er. I will bolt it to my d16y7 in the fall in see how my fuel economy reacts
Old Apr 23, 2006 | 10:34 PM
Bense's Avatar
bad idea. and not worth the effort.
Old Apr 24, 2006 | 05:50 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Bense)
Why do you htink so, the 3.25 signifacantly higher than my 3.722
Old Apr 24, 2006 | 08:58 AM
schardbody's Avatar
how much did you pay for the boat anchor. sure if you want mpg use it.
Old Apr 24, 2006 | 12:45 PM
Bense's Avatar
the difference is like 200rpm at 80mph in 5th gear between the final drives. Not enough to make a difference. The only real advantage is if you had a hx or vx engine with the lean burn and say you were doing LOTS of traveling on flat ground at a speed that was say 100rpm higher than where vtec engages.
Old Apr 24, 2006 | 03:27 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Bense)
257 miles, 5.3 gallons
4.25 FD and .771 5th gear, 3200 rpm and 65 mph.
Wait for the 60 mpg attempt in the fall
BongoBennie
Transmission & Drivetrain
Sep 14, 2015 02:07 PM
jaylivfortyfive
Mar 24, 2009 10:07 AM
BadEH2
Jan 24, 2005 07:31 PM
00-ITR-373
Mar 30, 2002 05:47 AM
gubo22
Oct 30, 2001 03:34 AM
