Final Drive for D series
New User
Does anybody know what options I have?
Looking for a 4.7 or 4.9
LSD is going in soon and want to put in final drive at the same time
New User
Re: Final Drive for D series (Mista Bone)
hey Mista Bone, glad you replied
I have 2 options:
Use my stock cx tranny and put in a final drive with the quaife lsd OR
use my 1992 Si tranny that needs to be rebuilt and just put in the lsd
i am using the Si tranny right now and it pops out of second gear in turns and the bearings are shot (very noisy)
the cx tranny is fine and only has about 30K miles on it...(hard miles though)
I figure a fairly new cx tranny with a 4.7 or 4.9 final gear would be faster than a rebuilt Si tranny with stock final gear
I spoke to Ben at A&J today and he said he has one in stock but I didn't have time to go into details...I think he said something about SRR making one? not sure...
any help you can give me will be greatly appreciated
I have 2 options:
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: Final Drive for D series (gubo22)
hey mista, he doesn't have only one option...ATS has a final for the d series tranny. www.racingcraft.com
D Tranny Guru
Re: Final Drive for D series (rodney)
Like I said, Houseman only option. He is making them for ATS. Since he can make batch runs for the masses, prices are cheaper. Will only fit L3 (88-91) cases though.
D Tranny Guru
If just the bearings are bad in a Si tranny, do a gut swap into the CX case. Since you are changing the diff, you'll need to reshim it anyway. If you "gut swap" the Si gear cluster into the CX case you'll have to do 2 things......
reshim the mainshaft and swap the second countershaft bearing.
If you look at a helms the DX/CX/VX uses a standard bearing on the countershaft just behind the bearing that uses the lock ring. The Si bearing will not fit into the CX/DX/VX case. I broke a case doing this!
Also replace the 1-2 shifter fork while tranny is apart, it only cost $50.
http://home.cinci.rr.com/mistab0ne/tranny.html
1 Post
houseman makes the gears for ATS? lol! who gave you that line? houseman? so, let me get this straight.....ATS of japan gets all it's gears from canada? well, i guess KAAZ gets their gears from canada too....
D Tranny Guru
didn't know ATS was a JDM company. I do know Jaime is making gearsets for a company. Many ITA racers want them.
Maybe OPM or someone?
cursED
04-09-2007 04:18 PM
