Stupid Turbo Install QUestion?
Old Apr 17, 2006 | 08:41 PM
juniestyle's Avatar
Default Stupid Turbo Install QUestion?
THis is my 1st turbo kit and i bought a drag turbo kit used...i was wondering on the turbo there are three holes, 1 for oil feed line, 2 for oil return line, and 3 i have no idea!!! What is that one for...is that one for coolant? Need help please...also i have the inline fuel pump that comes with the kit and it looks like i need a banjo bolt where the fuel line would be connected to the fuel rail...where would i get this part?
Old Apr 17, 2006 | 08:49 PM
s2kdre's Avatar
Default Re: Stupid Turbo Install QUestion? (juniestyle)
the other holes on the side are usually for coolant, but u dont have to use those.
Old Apr 17, 2006 | 08:58 PM
juniestyle's Avatar
Default Re: Stupid Turbo Install QUestion? (jdmhonda)
cool, so i can just leave it open!!! But would it help if i did connect it to a coolant line?
Old Apr 17, 2006 | 09:11 PM
stewie8apie's Avatar
yes...but its not necessary.
Old Apr 17, 2006 | 10:39 PM
RogueWorks's Avatar
Default Re: Stupid Turbo Install QUestion? (stewie8apie)
Are you talking about the threaded "hole" in the compressor housing?
Old Apr 17, 2006 | 11:57 PM
juniestyle's Avatar
Default Re: Stupid Turbo Install QUestion? (RogueWorks)
yes it is threaded on the compressor housing! is it better to hook up the wastegate to the compressor housing or to the intake manifold that leads to the brake booster?
Old Apr 18, 2006 | 12:16 AM
RogueWorks's Avatar
Yeah, be careful where you get advice. Nothing like pumping your charge pipes full of coolant
You can connect the wastegate to either the compressor housing or at the manifold/booster.
Old Apr 18, 2006 | 12:26 AM
4inspeed's Avatar
if you dont use that for the wastegate then plug it.... i personally use it for the wastegate.
Old Apr 18, 2006 | 07:46 AM
juniestyle's Avatar
Default Re: Stupid Turbo Install QUestion? (4inspeed)
i heard turbo response is not so good when u connect it to the compressor, and i heard turbo response is better at the intake manifold /booster, but will spike more than it would on the compressor...is this true?
kccord
May 26, 2009 06:08 AM
eg_21
Mar 8, 2009 10:46 AM
kauai96
Jun 1, 2008 06:31 PM
redlseg
May 15, 2005 04:32 AM
It's*BOLO!!
Mar 30, 2003 03:19 PM
