93 si with homemade turbo question
ok guys i'm getting ready to install my homemade turbo kit next weekend, but i'm a little cinfused on some of these stuff since is the first time i ever do a turbo set up, anyway the set up is an hf manifold with a plate welded on a ihi rhb5 vj11 turbo, i will be using a FMI but the question is where do i connect the 4 lines my turbo came with, i know about the feed line, and oil drain line, but the turbo has two more lines which are banjo bolt lines, i guess for water cool and oil cool, one of the lines will go to the the throttle body line, but where do i put the last line and are both of those supposed to be for water cooling or one is for water cool and the other one is for oil cool?? so in conclusion the turbo has 4 lines, i got use for three of them so far but where does the 4th one goes and does it matter which one is use for oil and water cool?? or one of them is specifically for oil and if mixed will mess up anything??
Thanks
Thanks
daluv
07-31-2008 12:20 PM
Scott - 93HB Si
09-04-2002 04:14 AM
