pistons for b18 c5 with 83 or 84 bore
hello
i will use in a b18 c5 engine pistons with a 83 or 84 mm bore.now it is 81mm.
but when i look,i dont find pistons for a integra.
do someone know wich piston i can use in this engine.i will have then a comp ratio about 11 and 12:1
i hope you understand my english.
i hope you are getting that block sleeved!
All You need is to buy some 83-84mm B series VTEC pistons from CP. Call Tom at Camp1320, he'll get you the right ones
@chris22215
why do you think ,that i need a sleeved block.
the engine is not with boost then.
it is now 190 HP and then i will tune up only to 220-230 HP
NO turbo and NO supercharged
i think i can use the block normal.not sleeved!?
Ralf
Ralf
it is a b18c5.and i want to bore up from 81mm to 83 or 84 mm.is it possible with the original sleeves.
the car is not charged
Ralf
Ralf
no you can't, the stock sleeves are aluminum with a steel sleeve.
that inner steel sleeve will be paperthin @ 84mm, just get it sleeved if your going to go that large.
I had a c5 also but threw a rod thru the block.R.I.P
L8R
L8R
I_got_your_honda
Aug 17, 2006 01:04 PM
jamessh1
May 28, 2004 04:30 PM
