how much boost can i run on dsm 440,s
Old Apr 16, 2006 | 02:56 PM
94integragsr's Avatar
Banned
Default how much boost can i run on dsm 440,s
im currently getting my built block installed and hoping to run 15 psi mabye a little more
i will be going to get tuned in like a month
Old Apr 16, 2006 | 02:59 PM
SpeedingHatch's Avatar
Default Re: how much boost can i run on dsm 440,s (94integragsr)
they are 450's. And most people say 300whp, but then theres fuel pressure and whatnot to get more
tegturbo's Avatar
i'm going to say no,but would help to know set up and engine and power goals....
Old Apr 16, 2006 | 03:50 PM
adseguy's Avatar
Default Re: how much boost can i run on dsm 440,s (tegturbo)
fueling needs are directly proportional to horsepower. Actually you can calculate pretty accurately how much horsepower you have by looking at how much fuel is being dumped an what AFR you have. Fuel curve matches the HP curve as well as long as the AFR is the same.
SOooooooo, 440cc has nothing to do with PSI. 440cc's are good for around 280-300whp staying at a good duty cycle and safe AFR's so as long as you don't want more then 280whp don't worry about larger injectors.
Old Apr 17, 2006 | 02:31 AM
Banned
Default Re: how much boost can i run on dsm 440,s (adseguy)
im looking for 350-400 so i will have to go bigger.
Old Apr 17, 2006 | 04:16 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">fueling needs are directly proportional to horsepower. Actually you can calculate pretty accurately how much horsepower you have by looking at how much fuel is being dumped an what AFR you have. Fuel curve matches the HP curve as well as long as the AFR is the same.
SOooooooo, 440cc has nothing to do with PSI. 440cc's are good for around 280-300whp staying at a good duty cycle and safe AFR's so as long as you don't want more then 280whp don't worry about larger injectors.</TD></TR></TABLE>
yup yup thats it.
Old Apr 17, 2006 | 04:44 AM
hatchonarun's Avatar
Default Re: how much boost can i run on dsm 440,s (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr &raquo;</TD></TR><TR><TD CLASS="quote">im looking for 350-400 so i will have to go bigger.</TD></TR></TABLE>
yes i suggest you get a bigger one like 650cc or even 750cc cause later on u would wanna boost more
Old Apr 17, 2006 | 07:29 AM
blackeg's Avatar
yes please do.
i blew a sleeve with dsm 450s at stock fuel pressure and about 325-340whp
eg:R
Dec 20, 2008 08:02 AM
SpeedingHatch
Dec 31, 2005 02:41 PM
The DX Rex
Dec 28, 2004 07:25 PM
The Destroyer
Jul 11, 2004 03:33 AM
turbo*s2k
Feb 25, 2004 11:50 AM
