b18b head on a b18a block questions, help plz.
I currently have a b18b obd2 head and im getting a b18a longblock.
Will i run into any problems if I just swap the heads? Only problem
I heard ill be recieving is with the PCV system, what can i do to resolve this issue?
Just reuse the B18A intake manifold and fuel injection parts and there won't be any issues. You could also run the hose from the intake manifold of the B18B down to the oil separater box on the back of the B18A block too. You gotta use the B18A valve cover or plug the PCV hole in the B18B cover.
racecarpete
Nov 24, 2002 04:10 PM
