JB vs. Tig Weld vs. Rubber washers
Old Apr 16, 2006 | 08:02 AM
.kyle's Avatar
Default JB vs. Tig Weld vs. Rubber washers oil return poll
hey guys im finishing up my turbo project EJ coupe and i was wondering if i should JB weld it tig weld it or just use a nut on the inside with rubber washers and some hondabond. . . *EDIT* on my oil return!! sorry about that!
Modified by IWantATurbo at 9:14 AM 4/16/2006
Old Apr 16, 2006 | 08:06 AM
95GSRTT
Guest
Posts: n/a
Default Re: JB vs. Tig Weld vs. Rubber washers (IWantATurbo)
lol jb, tig or use washers on what?
Old Apr 16, 2006 | 08:29 AM
JDMs1eeper's Avatar
Default Re: JB vs. Tig Weld vs. Rubber washers oil return poll (IWantATurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWantATurbo &raquo;</TD></TR><TR><TD CLASS="quote">hey guys im finishing up my turbo project EJ coupe and i was wondering if i should JB weld it tig weld it or just use a nut on the inside with rubber washers and some hondabond. . . *EDIT* on my oil return!! sorry about that!
Modified by IWantATurbo at 9:14 AM 4/16/2006</TD></TR></TABLE>
lol, D all of the above
JK, do you have a tig welder? If so Id use that. I know i do that to mine
Old Apr 16, 2006 | 08:33 AM
non-VTEC's Avatar
i tapped my pan with a brass barbed fitting and sealed it with JB weld..........holding up just fine......no leaks
if you have access to a welder then do it that way.......if not then be creative.
Old Apr 16, 2006 | 10:21 AM
stewie8apie's Avatar
Default Re: JB vs. Tig Weld vs. Rubber washers oil return poll (aallbbeerrtttttt)
i used jb weld for about 2 minutes....then it started leaking....maybe i just suck with jb but, i'd weld it if you can.
Old Apr 16, 2006 | 11:16 AM
drumking15's Avatar
Default Re: JB vs. Tig Weld vs. Rubber washers oil return poll (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i tapped my pan with a brass barbed fitting and sealed it with JB weld..........holding up just fine......no leaks
if you have access to a welder then do it that way.......if not then be creative.</TD></TR></TABLE>
exactly how i did mine...and all of my friends cars....a 3/4" tap & drill bit were a lil pricey.....you can get 1 or 2 good threads on the fitting and i used epoxy puddy around the edge of the fitting to add a lil reinforment and leak proofin...been workin great...no a dam drop of oil
Old Apr 16, 2006 | 01:32 PM
mr_hahn73's Avatar
Tig would be the right way. The most important is that it is sealed!
Old Apr 16, 2006 | 01:34 PM
N20civicB18's Avatar
braze it
Old Apr 16, 2006 | 02:41 PM
jfoster's Avatar
Default Re: JB vs. Tig Weld vs. Rubber washers oil return poll (N20civicB18)
I have known people that have used alot of JB weld and it worked without leaks but its a little to ghetto for me.
I used a fitting with a nut and copper crush washers coupled with teflon tape and copper spray gasket maker .... it leaks
Next oil change I am pulling the pan and welding it in. Welding is the obvious best choice in this scenario so even if you have to pay somebody $10 to weld it, thats so cheap there is really no reason to not do it right the first time and save yourself a future head ache.
T9U4ReBgO
Feb 24, 2008 07:09 AM
silentdaredevil2
Oct 21, 2006 05:33 AM
drift2004
Apr 20, 2005 10:55 AM
turboH22Aakkord
Apr 14, 2005 11:55 AM
Mr. Samurai
Feb 26, 2005 09:48 PM
