Motor Rev.
Old Apr 9, 2006 | 04:21 PM
De_tour's Avatar
Default Motor Rev.
Modified by De_tour at 6:27 AM 8/30/2008
Old Apr 9, 2006 | 04:23 PM
Lewy. Dee Ayy's Avatar
Default Re: Motor Rev. (wspcivic)
what motor are we talking about reving to 7k in?
Old Apr 9, 2006 | 04:27 PM
De_tour's Avatar
Default Re: Motor Rev. (WhiteOut)
Old Apr 9, 2006 | 04:35 PM
i dont kno what that redlines at..but im assuming its like 7-7.5k ...its fine everyonce in a wile...i have a d15...i drive that thing hard as hell everyday..i have to basicly redline every gear with my 70 hp..still running good..havent had any probs yet..so..have fun everyonce in a wile..redline her..its good for her
Old Apr 9, 2006 | 04:42 PM
donvito#1's Avatar
i reved out my crx almost every day and it still runs strong but after awhile your head will start ticking but like everybody knows that just a honda thing most you will have to do is adjust the valves if the happens other then that hondas are made to last have fun
Old Apr 9, 2006 | 04:51 PM
Soccerking3000's Avatar
Default Re: Motor Rev. (donvito#1)
you can rev to the stock redline in every gear and nothing is gunna happen, honda put those there as a safety point, i doubt they would put it above an rpm which could damage the motor...
edit and for taking it higher than redline is this what your tach says? because i bet it is just off 200 rpm...
Old Apr 9, 2006 | 05:08 PM
De_tour's Avatar
Default Re: Motor Rev. (Soccerking3000)
Modified by De_tour at 6:28 AM 8/30/2008
Old Apr 9, 2006 | 05:27 PM
your tach is off then, if you redline is 6800 it wont go any higher there is a fuel cutoff, which means that your tach isoff 200rpm in the higher range, it isnt uncommon for hondas at all
Old Apr 9, 2006 | 05:36 PM
De_tour's Avatar
Old Apr 9, 2006 | 05:56 PM
well its isnt a 7k redline, thats just what the tach reads... you still have a 6800 rpm redline/fuelcutoff
Old Apr 9, 2006 | 06:02 PM
De_tour's Avatar
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">your tach is off then, if you redline is 6800 it wont go any higher there is a fuel cutoff, which means that your tach isoff 200rpm in the higher range, it isnt uncommon for hondas at all</TD></TR></TABLE>
The B18B1 fuel cutoff is 7200 RPM. The redline on the tach is 6800 RPM.
Old Apr 9, 2006 | 06:06 PM
De_tour's Avatar
Default Re: Motor Rev. (Targa250R)
my tach goes to 11,000 and ive been going off of the redline specs that ive found online for my motor, which was a redline of 6800
so i somtimes end up shifting when my tach reads 7 to run it out.
Old Apr 9, 2006 | 06:16 PM
9295EJ-t's Avatar
dont over rev it.. you could drop a valve.. or bend a rod.. and you could even spin a bearing! just because your tach reads up to 11k, doesnt mean itll go there.. if you have a b18b, you should notice that you have almost literally no power after 6k anyways..
Old Apr 9, 2006 | 07:39 PM
turnsignalandy's Avatar
Default Re: (9295EJ-t)
i have a y8 and my reline is 6800 but itll go a little past it before the fuel cutoff kicks in. Anyways with my D16y8 most of the power is towrds the redline cause of the vtec.
Old Apr 9, 2006 | 07:43 PM
SOHC4life 96's Avatar
Default Re: (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">i have a y8 and my reline is 6800 but itll go a little past it before the fuel cutoff kicks in. Anyways with my D16y8 most of the power is towrds the redline cause of the vtec.</TD></TR></TABLE>
Not necessarily. Just because you have VTEC doesn't mean all of your power is up top. There is a point where the power of the engine will drop off. I'm not sure exactly where that is at. But you don't need to rev the **** out of your engine. Shifting might actually make you go faster.
Old Apr 10, 2006 | 12:15 PM
De_tour's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9295EJ-t &raquo;</TD></TR><TR><TD CLASS="quote">dont over rev it.. you could drop a valve.. or bend a rod.. and you could even spin a bearing! just because your tach reads up to 11k, doesnt mean itll go there.. if you have a b18b, you should notice that you have almost literally no power after 6k anyways..</TD></TR></TABLE>
i only go about 6-7k, i wish my motor would rev that high haah
Old Apr 10, 2006 | 01:10 PM
. a d a m's Avatar
I'm pretty sure he knows that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">The B18B1 fuel cutoff is 7200 RPM. The redline on the tach is 6800 RPM.</TD></TR></TABLE>
You're fine where you are, don't rev it any higher than that though, and I wouldn't recommend doing it everytime you get into your car either. I know people who beat the **** out of their car everytime they get in it, the results are never positive.
Old Apr 10, 2006 | 01:54 PM
Default Re: (Sh!ttyLS)
where's my free oil lines?
97grnrs
Apr 5, 2008 06:57 PM
gmboogy
Sep 4, 2006 07:59 PM
hondadriver
Mar 10, 2006 12:51 PM
JDM00SI
Jan 30, 2005 06:43 PM
Todd00
16
Jan 3, 2002 11:06 AM
