whats the stock bore
Old Apr 8, 2006 | 11:10 PM
steve96accord's Avatar
Default whats the stock bore
whats the stock bore on an f22b2? an is this a good deal http://www.importperformanceparts.net/ << go to Hp engine kits [],yellow.. thanks
Old Apr 9, 2006 | 07:31 AM
P_Adams's Avatar
Default Re: whats the stock bore (steve96accord)
Bore Spec (refered to as 85mm)
Piston Diameter: 84.970mm (3.3453in) Diameter
Piston / Cylinder Clearance: 0.05mm (0.002")
As to your linked site... what specifically were you looking at?
Ok, I see it, other than sticker shock (I used to buy pistons for $42.99 ec.) it looks ok. I'd go with the oil pump option. This would allow either higher compression or greater strength if you decided to boost.
P
Old Apr 11, 2006 | 11:27 PM
Default Re: whats the stock bore (P_Adams)
thanks P adam
Old Apr 12, 2006 | 11:00 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve96accord &raquo;</TD></TR><TR><TD CLASS="quote">http://www.importperformanceparts.net/ </TD></TR></TABLE>
those "engine kits" are deceiving. they don't have any of those in stock, it's all custom, made to order.
try race engineering instead, they actually stock this stuff.
Old Apr 12, 2006 | 11:41 AM
Default Re: whats the stock bore (notoriousB)
thanks.... u have the site?
Old Apr 12, 2006 | 11:42 AM
Thanks.. u have the website on that?
Old Apr 12, 2006 | 12:50 PM
notoriousB's Avatar
google: Race Engineering
it's not that hard. I'm not here to do all the work for you.
94IntegraDB8
Nov 28, 2007 07:48 AM
DB1_559
Jan 21, 2007 10:31 PM
LSVtechnologytur...
Jan 6, 2005 05:57 AM
MiKeAhOwSkI
Jun 16, 2004 07:20 PM
93H22ACX
May 18, 2004 04:55 PM
