.40 over piston rings..where?
Old Jun 16, 2004 | 12:56 PM
MiKeAhOwSkI's Avatar
Default .40 over piston rings..where?
Does anyone know where I can get some .40 oversized piston rings for my D16y8 motor? Does anyone even go that large? I'm trying to run FJT's vitara pistons, but I need to go oversized... and they only come in .40 over. Thanks for any help.
Old Jun 16, 2004 | 06:05 PM
earl's Avatar
Default Re: .40 over piston rings..where? (MiKeAhOwSkI)
Probably if anyone had them in stock, it would be Endyn.
Are you sure you can bore your D16 to 77mm and boost safely with it?
Old Jun 16, 2004 | 06:11 PM
igo4bmx's Avatar
Default Re: .40 over piston rings..where? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Probably if anyone had them in stock, it would be Endyn.
Are you sure you can bore your D16 to 77mm and boost safely with it?</TD></TR></TABLE>
just wondering but wouldn't it be better to get bigger pistons rather than bigger rings?
Old Jun 16, 2004 | 06:25 PM
I'm no engine expert by any means, but a while back we had this great idea of building a D18 (ls rods and pistons) and we were gonna be basically on the last strand before the edges of the sleeves after boring it out. But from what I've picked up (and I could be wrong) was that LS pistons are 81mm so I think 77mm would be okay? I'm trying to learn too, so let me know if I'm completely wrong.
Old Jun 16, 2004 | 06:47 PM
hotintegranights's Avatar
79.5mm would be the max even with sleeves so i would find it impossible to fit 81mm ls pistons in there. also boring out your stock block to .40 will be dangerous for boosting and will only yield you a couple more hp/tq not much,but since you have thinner walls you will have to boost lower to be safer, lower boost will yield less hp (of course) so iits not worth it.
Old Jun 16, 2004 | 07:20 PM
Default Re: .40 over piston rings..where? (hotintegranights)
Ahhh it all makes sense now. Thanks for the knowledge
AaronJ
May 1, 2008 05:42 PM
garyc17
Jun 12, 2007 02:26 AM
DB1_559
Jan 21, 2007 10:31 PM
Chillinit
Apr 24, 2005 09:04 AM
