quick obd2 to obd1 p28 question, missing at startup, rich
Old Apr 7, 2006 | 06:09 PM
darrinbrewer's Avatar
Default quick obd2 to obd1 p28 question, missing at startup, rich
wanted to run a stock p28 on my 96 because the cat;s gone, car still does run good on obd2, but the obd1 feels smoother and better
at startup, it misses and wont idle, like my teg after putting a big str TB on it with out the secondary idle thing on the bottom.
after warming, its fine and drives great. you guys think its a TB issue? and a obd1 with coolant flowing through will help?
Old Apr 7, 2006 | 06:13 PM
SVOboy's Avatar
Any codes? I'm guessing not, but hell, ya never know. Did you ***** with the ect compensation or anything like that that would affect not normal operating temperatures?
Old Apr 7, 2006 | 06:17 PM
Default Re: (SVOboy)
i ran both a stock p28 and a chipped p28 running a stock program. thought it was the harness( freind made it) but it runs fine after warm. acts just like my built integra, at startup its lumpy and rich, and if i lean it out in crome, it idles lean after warm, so i live with it, although i'd like to clear it up.(this started after getting a 74mm str TB on there)
i cant have this on teh 96 ex, its the dailey car
Old Apr 7, 2006 | 06:22 PM
SVOboy's Avatar
Does leaning out the warm up help on the teg? You can always just lean out the warm up part in the advanced tables part of crome. It must be something acting crummy with a sensor. Try unplugging **** and seeing how it affects things. That's part of how I discovered my iacv problem.
Old Apr 7, 2006 | 06:31 PM
it did a little, but like i said, i seen it leaning out after warm up.
as soon as the teg is started, it goes to 750 and trys to idle, it wont idle up when cold liek it used to with the factory bored out TB
Old Apr 7, 2006 | 06:40 PM
SVOboy's Avatar
If you adjust the ECT correction factors you can lean it out only during warm up and it uses the same normal temp fuel maps.
Old Apr 7, 2006 | 06:49 PM
i havent messed with crome in a while, my computer crashed and i had to reinstall, i dont see advanced tools, remind me please
Old Apr 7, 2006 | 06:51 PM
SVOboy's Avatar
CTRL + L
Old Apr 7, 2006 | 06:52 PM
not happening...running beta 1.1.2...is that a old one?
Old Apr 7, 2006 | 06:55 PM
SVOboy's Avatar
Hell, I dunno, try working off a p30 base. It's in one of the drop downs on the top right area too.
Old Apr 7, 2006 | 06:56 PM
it was there before, i remember it, i'll go DL the newest one. appreciate the crome tips and all,
but still havent figured out were to start on the 96 car with a stock p28
Old Apr 7, 2006 | 06:59 PM
SVOboy's Avatar
Well, that's what I thought I was talking about? Is this a del sol with an obd2 p28?
I'm slightly confused why the ecu would create such a problem just from going obd2 to obd1, hopefully someone can give a reason why and a fix.
Old Apr 7, 2006 | 07:04 PM
lol, we got to talking about my 95 gsr on crome,
the 96 has a obd1 conv harness and a stock p28 in it, it misses and is smells rich when 1st started..lol
Old Apr 7, 2006 | 07:11 PM
SVOboy's Avatar
But def no codes?
Old Apr 7, 2006 | 07:29 PM
no, no codes at all. still runs fine on obd2 computer, but also runs fine on obd1 AFTER its warm
jdm_vtec
Sep 6, 2007 11:12 AM
gsr_beats_20L_lsvtec
Mar 25, 2007 11:39 AM
BlueRex1020
Mar 4, 2007 12:41 PM
Lee_Delso
11
Dec 13, 2004 07:41 AM
SpeedBump
May 9, 2002 05:37 PM
