After rotating tires...
Old Apr 7, 2006 | 02:42 AM
easyFOsheezy's Avatar
Default After rotating tires...
I took the car for a drive and for some reason it pulls right whenever im driving. its not just on certain roads but pretty much all roads. its almost like i have to use some strength to keep the car going straight. i dont understand what would cause this. i have rotated my tires tons of times, but this is the first time this has happened. is a wheel alignment necessary? how often should i get my wheels aligned? any info appreciated. thanks.
Old Apr 7, 2006 | 02:58 AM
Chong's Avatar
ballin
Default Re: After rotating tires... (easyFOsheezy)
Tire pressures?
Old Apr 7, 2006 | 03:09 AM
KayOs's Avatar
are you using directional rotating tires? Check for corded tires or low tire pressure as mentioned above.
Old Apr 7, 2006 | 03:40 AM
Default Re: After rotating tires... (KayOs)
using yoko es100's. swapped back to front, front to back on both driver and passenger sides. tires pressures all stock spec.
Old Apr 7, 2006 | 11:04 AM
nsxtasy's Avatar
H-T Order of Merit
Pressures and mounting are the most obvious things and they're the easiest to check, and you've done that.
Other possibilities include an alignment problem, a problem with a tire (which can arise due to manufacturing defect, a puncture, etc), or a suspension problem (e.g. cracked bushings, etc) for which uneven tire wear can also be a visible symptom.
First, check all the tires visually to see if there is uneven tire wear or other signs of a problem. Then, try rotating the tires again and see if it still pulls. If the problem goes away, it's associated with one of the tires; if it doesn't, then get an alignment and also put the car up on a lift and check all the suspension components.
Old Apr 7, 2006 | 12:05 PM
Default Re: After rotating tires... (nsxtasy)
thanks nsx
when i was rotating tires i did notice there was uneven wear
happy to know its not a big problem
thanks guys
Old Apr 7, 2006 | 01:24 PM
nsxtasy's Avatar
H-T Order of Merit
Just keep in mind that the uneven wear may be a symptom of another problem (like in the suspension, like I mentioned). I would still check the suspension out next time it's up on a lift.
Also, if the tires wear more along both edges than in the center of the tread, that's often a symptom of underinflation, and greater wear in the center may reflect overinflation.
Vtec04
Sep 26, 2017 03:31 AM
jkillah29
Jan 13, 2013 10:52 AM
__oversea
Jan 12, 2010 07:51 AM
vladd
Feb 23, 2009 09:39 AM
SIXTYdashONE
Jan 29, 2003 04:05 PM
