Spring Rate Question..
Old Apr 6, 2006 | 06:32 PM
ITR0065's Avatar
Default Spring Rate Question..
I found a great set of Cusco Comp S Coilovers. My question is the guy has the spring rates listed as 8k in the front, 6k in the rear. My car is mostly a street car. Are these rates too stiff for the street? I am willing to sacrifice a little comfort, I'm just not looking for something that is going to be breaking my tailbone.
Thanks in advance guys.
-Eric
Old Apr 6, 2006 | 07:12 PM
jetydosa's Avatar
25 Year Member
Default Re: Spring Rate Question.. (ITR0065)
Those rates should be fine assuming the dampers are decent quality.
Old Apr 6, 2006 | 09:53 PM
itr1244's Avatar
Default Re: Spring Rate Question.. (jetydosa)
i dont think 8K , 6K is that stiff
should be ok for street use i guess
Old Apr 7, 2006 | 09:56 AM
ITR0065's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Those rates should be fine assuming the dampers are decent quality.</TD></TR></TABLE>
They are part of the Cusco Comp s Coilovers so I am assuming they are very good quality.
Anyone have any experience with these?
Old Apr 7, 2006 | 10:00 AM
silver j's Avatar
the quality will be fine, iirc they are made by showa. the only issue with the comp s is the ride height adjustability is not independant. i would expect as with most jdm coilovers for the shock to be valved on the stiff side. i thought about these but instead decided to go with the spoon dampers and progressive springs.
Old Apr 7, 2006 | 12:01 PM
ITR0065's Avatar
Default Re: (silver j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver j &raquo;</TD></TR><TR><TD CLASS="quote">the quality will be fine, iirc they are made by showa. the only issue with the comp s is the ride height adjustability is not independant. i would expect as with most jdm coilovers for the shock to be valved on the stiff side. i thought about these but instead decided to go with the spoon dampers and progressive springs.</TD></TR></TABLE>
When you say the ride height adjustablity is not independent, what do you mean by this?
Old Apr 7, 2006 | 02:31 PM
silver j's Avatar
maybe this will make a little more sense. take a look at the difference between the comp-s and zero1. it goes into detail right after the description of the zero1
http://www.cusco.co.jp/english/e_cont.html
Blizzard
Suspension & Brakes
Jul 7, 2006 06:25 PM
krys83
Suspension & Brakes
46
Mar 23, 2005 06:02 PM
JDM PRO
Apr 2, 2004 12:06 PM
JHD_DA
Mar 28, 2004 07:13 PM
combustion
Oct 23, 2003 05:50 AM
