Adjusting TPS Problem. Please Help!
Old Apr 4, 2006 | 11:04 AM
b18cEK's Avatar
Default Adjusting TPS Problem. Please Help!
Well when I try to adjust the TPS at closed throttle it just stays at .88V and does not move no matter what direction the tps is rotated.
Then the TPS at WOT moves between 3.8V and 4.6V
When i get the TPS to 4.5 at wot it idles around 3.5
Any imput is appreciated.
Old Apr 4, 2006 | 11:14 AM
SkRiBLaH's Avatar
Default Re: Adjusting TPS Problem. Please Help! (civic-rmod)
are you sure you have the TPS in correctally?
you can not just bolt it on and adjust it.
you have to match the little arm that comes out of the circle (the peice on the TPS that turns) match that up with the little holder on the throttle bracket.
you then turn it like 1/4 turn to match up the bolt holes.
its possible thats what your doing wrong.
Old Apr 4, 2006 | 11:19 AM
b18cEK's Avatar
Default Re: Adjusting TPS Problem. Please Help! (SkRiBLaH)
yeah, that is what I am doing. cause then there is resistance as you rotate the tps and the throttle moves...
Old Apr 4, 2006 | 11:43 AM
b18cEK's Avatar
and i am also throwing codes 3 (map) and 7 (tps) on my jdm d15b powered hatch
Old Apr 4, 2006 | 12:35 PM
fmrprojects's Avatar
maybe you have the map and tps plugs switched around too
Old Apr 4, 2006 | 12:48 PM
schardbody's Avatar
yep, i believe you are right.
Old Apr 4, 2006 | 01:06 PM
b18cEK's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">maybe you have the map and tps plugs switched around too</TD></TR></TABLE>
nope, the tps has the red/blue middle wire
Old Apr 4, 2006 | 02:36 PM
b18cEK's Avatar
ttt
Old Apr 4, 2006 | 04:09 PM
schardbody's Avatar
yep, red wire is TPS. bump
EFvtec Yo!
Jun 26, 2013 04:40 PM
gorsey
Aug 6, 2011 05:16 AM
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
SPOOLINmatt
Feb 2, 2007 08:04 PM
TheSav
Apr 10, 2006 11:23 PM
