ecu help needed
Old Apr 3, 2006 | 03:09 PM
dee16z6's Avatar
Default ecu help needed
i'm changing the head of my sohc d15b8 motor which is a 8 valve with a d15b7 16 valve head do i need to change the ecu or can i run with the same ecu
if i need to change which one should i use
thankz guyz
Old Apr 3, 2006 | 03:27 PM
moores55's Avatar
Default Re: ecu help needed (dee16z6)
get a p28 or an vafc.
Old Apr 3, 2006 | 03:30 PM
MISHN's Avatar
you might need to change ECUs. not to sure though. u can try the ECU that u have, if it runs like crap then u know it might be your ECU. i would get a P28 if anything.
Old Apr 3, 2006 | 03:47 PM
**DOHC HaTcH**'s Avatar
Default Re: ecu help needed (EG6 RITZ)
im pretty sure you can run the same ecu.
Old Apr 3, 2006 | 04:17 PM
SVOboy's Avatar
If you wanna run lean and with dramatically different timing tables, run a p05.
But to run it right, get a p06, and a 4 wire.
Old Apr 3, 2006 | 04:28 PM
eg6ajk's Avatar
easiest way is to chip it, and run P06 maps on the ecu. Otherwise find yourself P06 or JDM P29/P76 ecu
btw. this being shamless plug: I sell kit and chip for $20US shipped
if not simply start here:
http://www.pgmfi.org/twiki/bin/view/Home/WebHome
Old Apr 11, 2006 | 06:40 PM
vtec-adykt's Avatar
you can use the same one. You dont need to change it unless you will be using vtec.
LS stretch
Engine Management and Tuning
Feb 3, 2009 08:40 AM
95sloweg
Jan 14, 2008 05:46 PM
trustnoone7935
Nov 24, 2004 08:34 PM
Doubledeala
Oct 15, 2004 05:00 AM
ABK
Jul 25, 2004 05:07 PM
