Battery? Alternator? Something else?
Old Apr 2, 2006 | 09:18 PM
flatblack-h22's Avatar
Default Battery? Alternator? Something else?
okay, having some power issues. my car wont crank without the help of cables. there is no battery sign or check engine light. the car would drive for a good 5mins or so then it would start to lose power. it would also sound to be misfiring. you can hear pops pops pops in between the exhaust sound.
LS in a hatch.
sprayed the enginebay down 2 days ago.
Modified by mr.EGg at 1:39 AM 4/3/2006
Old Apr 3, 2006 | 12:42 AM
PurEvl's Avatar
Default Re: Battery? Alternator? Something else? (aallbbeerrtttttt)
did u make sure the wires off the engine harness are screwed into the fusse box in the engine bay?
is your start powered directly to the battery?
grounded?
Old Apr 3, 2006 | 12:46 AM
Rubixcu7's Avatar
Default Re: Battery? Alternator? Something else? (mr.EGg)
sounds like alt aint charging the batt.... check fuse 15 (i think) under ur dash... its the alt/speed sensor fuse... if not its plolly ur alt
Old Apr 3, 2006 | 01:50 AM
ImportMotorSpec's Avatar
Default Re: Battery? Alternator? Something else? (Rubixcu7)
Sounds like a ground issue to me. Redo all your engine/tranny grounds with bigger wire and clean bolting surfaces off to bare metal. Also, check your main harness ground on the thermostat housing.
Old Apr 3, 2006 | 08:30 AM
i'll be checkin it out.
is a dseries alt. the same as a b?
edit:
started the car up, took of the (-) terminal and the car died. that would mean the alt. correct? check the ground on the alt and the "O" for the ground was corroded(sp?) and broken off. i'll try to fix that and see wussup.
Modified by mr.EGg at 12:46 PM 4/3/2006
edit:
it works.! hm
Modified by mr.EGg at 1:31 PM 4/3/2006
civicboy420
27
Aug 20, 2014 07:53 PM
GPC91
May 7, 2013 09:06 PM
R-81DC2
Jun 5, 2007 09:21 AM
b16a1eg6
Jan 19, 2007 03:10 PM
92HB_HB
Aug 23, 2006 06:57 PM
