Battery charging issues
I have a 1997 Civic DX. When the car is running the volt meter I have show only 12.8 volts. When all lights , heater, rear defrost, and wipers are on it goes down to around 11.9-12.2 volts. I changed the altenator. Changed the fuse box to replace the load sensor. It still has the problem. Any ideas?
Re: (b16a1eg6)
See how much give, if we're talking give to the point that it's slipping...then it's not gonna turn and charge like it should. Maybe tighten it a bit.
Re: (gents97civ)
2nd vote for check that VSS/ALT fuse. I think it's #15 if memory serves.
Had the same problem with my wife's 98 LX. Ended up being a wire in a harness way up under the intake mani that had rubbed so long that the insulation was gone and was shorting to ground, blowing that fuse every time. A little heat shrink and taping the harness up to keep it from rubbing and we were good to go.
