Removing Harmonic Balancer
Ok the engine is out and it is on a stand. We tried to remove the harmonic balancer but that pully is not stable nor can we get it too the point where the nut in the middle of it will beak loose. We need to remove it in order to redo the timing. Any suggestions?
you need a special tool or somehow ghetto lock the flywheel to keep the motor from turning while you try to break the bolt loose. 19mm is not a special tool.
92EGMINIME
33
Feb 8, 2009 12:00 PM
tegmaniac
Aug 18, 2006 08:13 AM
imsagtrx7
Jul 5, 2004 08:54 PM
VWkila
17
Mar 31, 2004 05:53 PM
