How to remove flywheel?
Old Jul 28, 2001 | 01:42 PM
Akira-R's Avatar
Default How to remove flywheel?
Sorry if this is a dumb question but.........
How do you remove the bolts from the flywheel?
Do i need to use some sort of wrench on the crank to keep it from moving?
If anyone has an easy wya of doing it, I'd love to hear it!
thnx,
--reid
Old Jul 28, 2001 | 03:37 PM
sgT's Avatar
sgT
Default Re: How to remove flywheel? (Akira-R)
Impact gun.
If you dont have one, you must lock the flywheel. You can put a screwdriver through
one of the clutch bolt holes and brace it against the block next to the oil pan.
Its not easy though.
Old Jul 29, 2001 | 03:14 AM
JDM R98's Avatar
Default Re: How to remove flywheel? (sgT)
remove tranny,and then remove clutch,and then there the flywheel..simply just use a impact wrench like sGt said or the screw driver method..probaly need two people in order to do dat..
Old Jul 29, 2001 | 07:05 AM
Akira-R's Avatar
Actually I used a breaker with a 19mm on the crank side and proped it against the ground.
Then was able to get the bolts off the flywheel. I wish i had an impact gun/air tools
thnx for all the help.
--reid
Old Jul 29, 2001 | 12:00 PM
BABY NSX's Avatar
Am I the only one who thinks using an impact gun on (or around) your main crank is a truly bad idea? Nothing is worse on bearings then the kind of shock loads impact guns create?
Why not use the right tools as suggested in the Honda manual? There exists a ring gear lock to hold the flywheel while the bolts are carefully removed/installed with a non-impact ratchet. Remember your going to want to torque them down properly when you re-install them! But hey it's your engine!
Regards,
JDMInspired
Honda Civic (2001 - 2005)
Mar 17, 2008 08:57 AM
Schultzie
Jan 16, 2008 09:41 AM
.Thomas
Jan 16, 2007 10:45 PM
Ronin150
Feb 8, 2005 06:29 AM
Akira-R
Jul 29, 2001 04:43 AM
