How do you remove this bolt that holds the flywheel?
Re: (nojoke)
17mm 12point socket... i just finish putting mines on and now taking a break... be sure to put on a healthy dose of LOCKTITE... dont ask me why but i found out the hard way
EDIT: damn you guys are quick
Re: (DOHCtorTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST »</TD></TR><TR><TD CLASS="quote">17mm 12point socket... i just finish putting mines on and now taking a break... be sure to put on a healthy dose of LOCKTITE... dont ask me why but i found out the hard way
EDIT: damn you guys are quick</TD></TR></TABLE>
red? blue?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrctr »</TD></TR><TR><TD CLASS="quote">12 point 17mm have someone hold the crank and the same time....</TD></TR></TABLE>
hold the crank? what cha mean? i will be installing a clutch and flywheel soon. Any more tips?
red? blue?
Re: (GSRrR)
If the motor is in the car you will need to hold the crank pulley with a ratchet. Or else all you will do is turn the crank. If it's out the ratchet will wedge itself against the floor.
Re: (GSRrR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRrR »</TD></TR><TR><TD CLASS="quote">oh i see what you mean. i would be using air tools. think its still needed?</TD></TR></TABLE>
Nope.
Nope.
Re: (DOHCtorTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST »</TD></TR><TR><TD CLASS="quote">be sure to put on a healthy dose of LOCKTITE... dont ask me why but i found out the hard way
yes, please use some locktite. 3 of my flywheel bolts backed out at the dragstrip and I had to make it back home with ONLY 3rd gear for 60 miles. I also got a flat tire on the way.
Haven't been back to the strip since.
Re: (VWkila)
I called my honda dealer and talked to the head mechanic about this elusive "honda crank pulley tool" and he said he had never heard of it. Where did you get yours?
Re: (SearchBeforeUPost!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! »</TD></TR><TR><TD CLASS="quote">I called my honda dealer and talked to the head mechanic about this elusive "honda crank pulley tool" and he said he had never heard of it. Where did you get yours?</TD></TR></TABLE>
i got the moroso one.
which loctite did you use? red/blue?
Moderator
Re: (krzyaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krzyaccord »</TD></TR><TR><TD CLASS="quote">12 point 17mm socket </TD></TR></TABLE>
and a big impact gun!!!
Checkout the picture on the bottom of the page. It's the same one I have. I really can't remember where I got it... I think I followed a link from honda-tech.com..
https://honda-tech.com/zerothread?id=731651
here's a link to a cheap one
http://cgi.ebay.com/ebaymotors...49318
i have the moroso one, which doesnt fit as tight as it should. A lot of play in it, but it still works.
