Sub idea....feedback
Old Mar 30, 2006 | 03:59 PM
EF_ST@TUS's Avatar
Default Sub idea....feedback
I was thinking about putting my rear flooring back in and having a custom box to fill the space where my spare used to be. When complete it would be only the face of the sub showing with a grill over it of course. carpet all around that.
also this isnt my car i would have a little cargo compartment in front. CRX
Old Mar 30, 2006 | 04:05 PM
civhatch90's Avatar
i used to have a custom made sub box that would cover everything behind the seats but thiefs forced me to remove it. sound system will surely be improved with a sub in there do whatever you want
Old Mar 30, 2006 | 04:18 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: (civhatch90)
It's been done. I'm sure I have pictures somewhere. I also used to know of a write up, but I haven't seen it in years. What I would do is build it up enough that you could put the carpet over the grill. Out of sight, out of would be thieves minds...
Old Mar 30, 2006 | 04:20 PM
EF_ST@TUS's Avatar
Default Re: (h8tred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8tred &raquo;</TD></TR><TR><TD CLASS="quote">It's been done. I'm sure I have pictures somewhere. I also used to know of a write up, but I haven't seen it in years. What I would do is build it up enough that you could put the carpet over the grill. Out of sight, out of would be thieves minds...</TD></TR></TABLE>
I like it
Old Mar 30, 2006 | 04:38 PM
h8tred's Avatar
Default Re: (Lost_in_a_world_so_cold)
Haha, I can't find the site, but if you look up info on finding chamber volume using water, and read up on some basic fiberglass skills. Here's the run down from what I remember. Use some plastic liner to line the spare well, and pour in water until you've reached the proper volume for your speaker, then measure. Then get the water out by bailing, or using a shop vac (Wet/dry), and then line it with aluminum foil. Then comes the fiberglass work. The idea of this was to have a tight fight, but it's also removable. As for the building it up that I'm talking about. You would want to find out the maximum travel of your woofer, and give it a quarter inch or so more than it needs, put your grill over top of that, and cut a hole, or many small holes in the cardboard crap that lays over the spare.
If you're lazy, they also make subs that fit right into the spare tire itself, I think the RSXs with the premium sound package come with these. Pioneer made one as well.
Good luck, and keep us updated with pictures if you decide to go the DIY route. I hope I at least got you going in the right direction...
P.s. Use MDF for any framing that you do, it's available at Lowes or Home Depot.
Old Mar 30, 2006 | 05:13 PM
Maxximtl's Avatar
If you are going to undertake the project, I'd recommend reading up on the sound domain forums. There are a lot of considerations when doing a spare tire sub enclosure. Fiberglass is pretty easy to work with, but you need to add a few steps to properly dampen the enclosure (so the sub doesn't sound hollow or buzzy.) You will find several how-to articles on that forum.
Old Apr 1, 2006 | 01:02 PM
h8tred's Avatar
Default Re: (Maxximtl)
I think the one I read said something about putting some sort of foam or rubber between the fiberglass and sheet metal. I can't be sure though, I could hide my own easter eggs. Read read read is the best thing I could say, there are tons of box building sites. Personally, I have a 10 in a small bandpass box. Doesn't matter as the car isn't running though. I'm the death dealer to rods and rod bearings haha. I hate me so much.
Old Apr 1, 2006 | 03:01 PM
GSRCRXsi's Avatar
i used to have a custom box there. thieves ended that though. sounded good while it lasted
noname87
Honda CR-V & Element
12
Jul 14, 2014 04:17 AM
JDM_SOHC
Audio / Security / Video
Jul 21, 2012 01:03 PM
teg racer 877
Jan 23, 2011 04:23 PM
thw_goalie
Aug 16, 2007 06:08 AM
sinful
Aug 16, 2003 07:33 PM
