My car idles weird on start ups
Old Mar 29, 2006 | 03:14 AM
lhd dc2's Avatar
Default My car idles weird on start ups
I got a 93 CX with a b18b1 swap. When I go to start my car for the first time in the morning the car idles about 2.5k and then it drops to about 2k and just idles up and down. Its pretty annoying. Any ideas? I see no loose vaccum lines or leaks. TIA>
Old Mar 29, 2006 | 04:50 AM
sheBangZ's Avatar
Default Re: My car idles weird on start ups (LHD EG)
most likely your fitv. Its on the bottom of your throttle body. take it off witht he 3 i believe 10 mm? and pull off the coolant hose. at the end there is a plate held on by 2 phillips head screws. Once you get that off, inside you'll see a piston. Take a flat head and put it into the slot, and screw it back in as far as you can go. Now put it all back together and your done.
Old Mar 29, 2006 | 04:04 PM
lhd dc2's Avatar
I will try that out.
bump
delslow45
Jun 2, 2010 01:53 PM
pheardone
Jan 3, 2009 01:46 PM
daluv
Jul 13, 2007 07:56 AM
NeKe1point0
Feb 18, 2007 02:12 PM
SpoonN1
Apr 6, 2003 08:45 PM
