headlight fogd
Old Mar 28, 2006 | 05:16 PM
5lugSlug's Avatar
Default headlight fogd
how do i remove the fog/moisture in my headlight??
Old Mar 28, 2006 | 05:27 PM
Padawan's Avatar
Darth ModerVader
Default Re: headlight fogd (EJacul8)
The most thorough way would be to remove the bulbs and leave the lamp in a dry location until all the moisture is gone. You can also accelerate the process using a hair dryer. Make sure that you check and repair any seals around the lamp which would be responsible for the initial water leakage.
bsixteen's Avatar
edit: read it wrong my bad!
edit2:
https://honda-tech.com/zerothread?id=1152328
https://honda-tech.com/zerothread?id=524527
Old Mar 28, 2006 | 05:31 PM
5lugSlug's Avatar
Default Re: headlight fogd (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote"> Make sure that you check and repair any seals around the lamp which would be responsible for the initial water leakage.</TD></TR></TABLE>
maybe i should get a seal too then... P:JDM didnt have it on the lights
guessinthe2000
Honda Motorcycles
Apr 26, 2007 09:38 AM
rickm
15
Jan 27, 2007 01:40 PM
EFresh
Feb 14, 2006 07:42 PM
90gs
Oct 23, 2005 11:55 PM
NorthernXposure
Apr 14, 2005 07:58 PM
