NEED HELP!!! NEW SKUNK2 STAGE 2 CAMS IN B16
Old Mar 28, 2006 | 04:34 PM
DA9TEG305's Avatar
Default NEED HELP!!! NEW SKUNK2 STAGE 2 CAMS IN B16
I JUS INSTALLED SKUNK2 STAGE 2 CAMS IN A B16A BUT THE CAR TURNS ON AND RUNS BUT IT BEGINS 2 OVER HEAT AND IT IDLES AT 3000 rpm I THINK ITS THE TIMING WAT DO YOU THINK.....CAN SOMEONE GIVE ME A DETAILED WAY TO DO THE TIMING PLEASE HELP......
Old Mar 29, 2006 | 12:16 AM
UncleD's Avatar
Default Re: NEED HELP!!! NEW SKUNK2 STAGE 2 CAMS IN B16 (DA9TEG305)
I think you need to turn your caps off.
Old Mar 29, 2006 | 03:59 AM
mar778c's Avatar
Community Builder
Community Influencer
Yeah, check timing, for vacuum leaks, IACV, FITV
Old Mar 29, 2006 | 05:48 AM
Natural Aspirations's Avatar
Check your CAM timing.
What all did you remove for the cam swap?
Old Mar 29, 2006 | 06:49 AM
existanzcivicb20's Avatar
Default Re: (crixzc)
did you take the tps off for any reason. if you did check that you might have put it on the wrong way
Old Mar 29, 2006 | 06:56 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9TEG305 &raquo;</TD></TR><TR><TD CLASS="quote">WAT DO YOU THINK</TD></TR></TABLE>
I think that your cam timing is fuxored, you need to turn off your caps lock, and your english skills could use a little work.
Old Mar 29, 2006 | 09:02 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: NEED HELP!!! NEW SKUNK2 STAGE 2 CAMS IN B16 (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
I think that your cam timing is fuxored, you need to turn off your caps lock, and your english skills could use a little work.</TD></TR></TABLE> lol
Old Mar 29, 2006 | 09:08 AM
JDM B16A's Avatar
LMFAO!!
Old Mar 29, 2006 | 09:14 AM
Default Re: NEED HELP!!! NEW SKUNK2 STAGE 2 CAMS IN B16 (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">LMFAO!! </TD></TR></TABLE>
WoW this is 2 posts now that you have added nothung to.
jrubenis
May 9, 2005 09:55 PM
bb6h22
Oct 11, 2004 10:28 PM
tbud454
22
Aug 30, 2004 11:30 AM
Gump
14
Apr 27, 2004 08:40 PM
GreenR
Jul 18, 2002 05:26 AM
