Help with Timing PLEASE
Old Jul 17, 2002 | 03:47 AM
GreenR's Avatar
Default Help with Timing PLEASE
My timing advanced all the way is only at 13 degrees. Any suggestions on the problem maybe the cams? (Skunk2 stage 2)
Old Jul 17, 2002 | 04:31 AM
JPP's Avatar
JPP
Default Re: Help with Timing PLEASE (GreenR)
Are you talking about the ignition timing?
If so what steps did you take to advance it ? (just to make sure you didn't forget anything)
Old Jul 17, 2002 | 04:57 PM
t's Avatar
t
slot the distributor more.
Old Jul 17, 2002 | 05:18 PM
1GreyTeg's Avatar
This will help you hopefully: http://www.team-integra.net/sections...?ArticleID=235
Read it and use it's links.
Good luck,
A.
Old Jul 17, 2002 | 05:35 PM
sgT's Avatar
sgT
Default Re: Help with Timing PLEASE (t)
Definitely NO.
Either the cam timing is off which means your cam gears are off or
you need to adjust the intake cam because thats the way it was made.
Old Jul 17, 2002 | 05:48 PM
t's Avatar
t
Default Re: Help with Timing PLEASE (sgT)
Definitely NO.
done many times before for cylinder heads that were milled.
Old Jul 17, 2002 | 06:09 PM
Tomakit's Avatar
Definitely NO.
Any blatant visual clues to see if the cam gears/cam timing is off? I'm a self-professed noob at this stuff.
Tom
Old Jul 18, 2002 | 05:26 AM
JPP's Avatar
JPP
Default Re: Help with Timing PLEASE (Tomakit)
Definitely NO.
Tom
Well if you have stock camgears / camshafts, when the #1 piston is at TDC (white line on the crank pulley align with the pointer on the lower plastic cover) the mark on each camgears should be aligned with each other in between the camgears.
If you have adjustable camgears, everything should be aligned the same as above but even if you are set at 0-0 on the camgears that doesn't mean that the camshafts (and timing)are properly set (manufacturer error...) so you should always check the ignition timing with a timing light and camshaft timing on the dyno.
If you have a thinner head gasket or a milled head, then the markings won't line up, no matter how much you try.
Hope this help
Treyschls
Apr 13, 2023 07:04 AM
JdmIntegra98
Jun 9, 2004 04:25 PM
has-t
Jul 1, 2003 09:58 AM
Mr.Integra
May 22, 2003 12:41 AM
Jockobo
Jan 23, 2003 03:48 PM
