lower ball joint nut n screw stripped HELP!!!!!!
Old Mar 28, 2006 | 08:32 AM
JDM_SOHC's Avatar
Default lower ball joint nut n screw stripped HELP!!!!!!
I stripped the nut that connects the lower ball joint bolt to the castle nut that goes on it, an the castle nut is stripped as well... I honestly have no clue what to do, can i replace just that bolt an screw..?? do i have to replace the whole thing..?? anyone else have this problem..?? This is my daily driver so I can afford to not have a car for work an im tryna get this done ASAP..... help please...!!
Old Mar 28, 2006 | 09:07 AM
mperezkr's Avatar
Default Re: lower ball joint nut n screw stripped HELP!!!!!! (JDM_SOHC)
time for a new lower ball joint
Old Mar 28, 2006 | 09:10 AM
JDM_SOHC's Avatar
Default Re: lower ball joint nut n screw stripped HELP!!!!!! (mperezkr)
damn, i dont have time/money to bring my **** somewhere an have it pressed an all that.. from what i've read up an searched on it seems like everyone responds with "bring it somewhere to have pressed in" ect...... theres no way to knock out the old one an hammer in the new one..???
Old Mar 28, 2006 | 09:11 AM
egcivic's Avatar
https://honda-tech.com/zerothread?id=1553878
and ur gonna have to get a new one pressed in i think, that or find some way to press it in. i dunno if thats safe tho
jus search it these are often problems in civics im sure theres plenty of info
https://honda-tech.com/zerothread?id=1465226
says you car hammer it in, if you realli dont want to rent the tool or dont have the cash
but its not gauranteed i would do it right the first time if you have the chance
Old Mar 28, 2006 | 09:17 AM
mperezkr's Avatar
Default Re: lower ball joint nut n screw stripped HELP!!!!!! (egcivic)
i took off the spindle, put it on a vice, got a socket just the right size and hammered out the ball joint. and vice-versa for installing
Old Mar 28, 2006 | 09:23 AM
Cyberdx16's Avatar
i would first try to rethread the ball joint and get a new castle nut. thats what i did when this happened to me
Old Mar 28, 2006 | 09:25 AM
john666's Avatar
bring it to a shop. my buddy didnt listen to me and lucky from him he has AAA and a messed up rim.
Old Mar 28, 2006 | 09:31 AM
TurboEM1's Avatar
Default Re: lower ball joint nut n screw stripped HELP!!!!!! (Cyberdx16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 &raquo;</TD></TR><TR><TD CLASS="quote">i would first try to rethread the ball joint and get a new castle nut. thats what i did when this happened to me
definately do this first. find out what the thread is and get a die. re thread it. go to the honda dealer and get another nut. they will probably have to order it but you can use a regular nut for the time being. the threads dont look TOO bad.
Old Mar 28, 2006 | 09:34 AM
Lee_Delso's Avatar
Default Re: lower ball joint nut n screw stripped HELP!!!!!! (TurboEM1)
If you can try to rethread it but I think you should just go ahead and replace it. And yes you can do it without having to press it in and out. Let me see if I can find you that thread......btw search is your friend...here's one of the many thread about your situation....
https://honda-tech.com/zerothread?id=1279654
Here's another one that might help you out....https://honda-tech.com/zerothread?id=1155081
Old Mar 28, 2006 | 10:13 AM
mperezkr's Avatar
Default Re: lower ball joint nut n screw stripped HELP!!!!!! (Lee_Delso)
replace it, i rethreaded mine once and we'll leave at that. ended up having to replace it later on
Old Mar 28, 2006 | 01:30 PM
JDM_SOHC's Avatar
ok well i just got done doing lower ball joint, an new cv axle both on passengers side... now that infamous knocking noise that was occuring everytime i let off the gas while driving before i did the job is even LOUDER..!!! im stumped.... new axles, tie rods, ball joints, rotors, brakes, an tires balanced an it still every time i let off the gas while im driving goes KNOCK KNOCK KNOCK KNOCK KNOCK, than when i start back on the gas it goes away..... im starting to think crazy here, maybe where the cv goes into the tranny, the gears are messed up...??? could it be shocks...?? AHHHHHHHHHHHHHHHHHHHHHHHHH
Also to add, i've got the car jacked up on jackstands right now an when i accelerate then decel there is no noise, but since i dont have LSD i dont think both wheels should spin when i hit the gas cuz the passenger one doesnt, but when i free spin it with my hands i can kinda hear a faint knocking/rubbing noise... im so stumped man this sucks....
Old Mar 28, 2006 | 02:03 PM
JDM_SOHC's Avatar
Default Still knocking....!!!
bump
Old Mar 29, 2006 | 05:44 AM
mperezkr's Avatar
Default Re: Still knocking....!!! (JDM_SOHC)
bump cause does the same ****, but my sounds more like a grinding then knock
Juans_MX3
42
Jul 10, 2021 04:38 PM
kenzo42
Sep 5, 2013 05:45 AM
93(Civic)EG6
Sep 1, 2007 08:06 PM
tuphatt
11
Sep 15, 2004 12:10 AM
nugget8000
Aug 27, 2001 09:37 PM
