H22A tranny problem (reverse)
Old Mar 25, 2006 | 11:40 AM
xJDM H22Ax's Avatar
Default H22A tranny problem (reverse)
Well, last night after some races i go home. When i go to back in the car it doesnt go into reverse at all. Like if there was no reverse or a wall or something keeping it from going into reverse. I did miss 5th, maybe that will help figure out the problem. I can drive the car perfectly going through all the gears 1-5 no problem.
Please someone help asap! Thanx a million.
Old Mar 25, 2006 | 03:24 PM
xJDM H22Ax's Avatar
TTT
Modified by xJDM H22Ax at 11:51 PM 3/25/2006
Old Mar 25, 2006 | 03:28 PM
boosted96midorihatch's Avatar
Default Re: (xJDM H22Ax)
i lost my reverse in my h22 civic once after a bunch of racing and alls i did was pump my clutch and it came back
Old Mar 25, 2006 | 10:53 PM
xJDM H22Ax's Avatar
Default Re: (boosted96midorihatch)
Thanx man, did the same thing happen that it just would go in at all? well imma try it later today and hope it works! thanx a million
Old Mar 26, 2006 | 12:31 AM
yup wouldnt go in . so did it work????????
Old Mar 26, 2006 | 06:10 AM
xJDM H22Ax's Avatar
i gonna try in a little while. How many times do i pup the clutch?
Old Mar 26, 2006 | 06:59 AM
Syndacate's Avatar
enough, 10 or so...
ANyways.
u missed fith? what did u put it into? 3rd? Or you pulled the clutch too early?
I mean I could see if it waslike the camaros where reverse is where 5th is so if u slam it up into 5th too hard u miss and nail reverse (which locks the tires I might (knowing from personal experience)), but how does missing 5th relate to the reverse, and how exactly did u miss 5th?
(I'm not flaming, I'm j/w)
Old Mar 26, 2006 | 07:49 AM
xJDM H22Ax's Avatar
Default Re: (Syndacate)
i pumped it and it didnt work.
I didnt throw in 5th all the way and let the clutch go. I wasnt saying that it is related but stated it just incase.
I believe reverse gear is gone, im going to take it to a mechanic tomorrow and have them check it. I hope its not to expensive.
could it be a fork or something?
Old Mar 26, 2006 | 12:16 PM
IN VTEC's Avatar
Does it feel like it's blocked out of the reverse slot?
Here's what I think. Your transmission probably needs a 5th-reverse synchro set. It's around $100. The part number is: 23626-P16-316
The other possibilities are the reverse change holder (no real likely, but still possible) or a damaged reverse idler gear (very very unlikely).
If the shift fork was bent, you'd also experience problems with 5th gear as well. A bent shift fork is an unlikely problem since the part on the shift fork that interacts with the reverse change holder is too low on the shift to really be affected by a slight bend.
https://honda-tech.com/zerothread?id=1118121
Old Mar 26, 2006 | 02:45 PM
xJDM H22Ax's Avatar
Default Re: (IN VTEC)
Thanx alot man. Yea it feels like its blocked off.
Old Mar 27, 2006 | 04:56 PM
Syndacate's Avatar
so shouldn't you be able to slide into reverse anyways? Without syncros? move it forward I guess, should make a lil cracking sound, but it should slip in, no?
Old Mar 28, 2006 | 05:35 AM
xJDM H22Ax's Avatar
nope nothing worked... its over at a local honda dealer they are going to take it apart and get to the bottom of it.
BlueStar
Jul 26, 2008 07:14 PM
h22Hatchy
Jan 10, 2005 09:09 AM
h22Hatchy
Jan 9, 2005 03:21 PM
h22a1300177
Sep 16, 2003 08:49 PM
Dorikamu
Nov 6, 2002 07:46 PM
