Wastegate opening at idle
Well i just got my manifold back after almost 3 weeks and now i finally get it bolted up and the 44MM wastegate is open at idle.
Can anyone explain this to me ? What would cause this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">did you put the fire ring in the wastegate before you put it on?</TD></TR></TABLE>
Sounds right to me. I neglected the fire ring once and mine would open at idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki »</TD></TR><TR><TD CLASS="quote">Is manifold vacuum being applied to the diaphragm of the wastegate? That could unseat the valve during idle.</TD></TR></TABLE>
yup
you probably have the vac lines run incorrectly
yup
Yo i have the line comming off of the intake manifold and run to the side of the wastegate correction on the top!!!
ERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR i get the stupid award!!! been doing this for 6 years and never Thanx guys for the help
