confirm everything i need to put a GSR B18c in a EK civic
Old Mar 21, 2006 | 02:03 AM
silenttones's Avatar
Default confirm everything i need to put a GSR B18c in a EK civic
i was told if i buy the complete swap b18c...
i would still need to get...
mounts (d-series mounts is different for a b series?)
axles (d-series axles are different?)
EX wiring harness (for vtec)
shift linkage (i have a d16y7)
because its all made for a Integra.
if this is all correct, whats the estimated prices for each? thanks.
Old Mar 21, 2006 | 03:52 AM
erasable180's Avatar
Default Re: confirm everything i need to put a GSR B18c in a EK civic (silenttones)
the mounts, axles, and shift linkages are indeed different. you dont have to get an ex harness you can wire into your existing harness. axles $50 ea, mounts, linkage not too sure about, but definitely a little more.
Old Mar 21, 2006 | 04:11 AM
strokedb16delsol's Avatar
i did this swap in my old car. i had a 99 ek with 2001 gs-r swap. make sure you get a B16 rear motor mount and profab driver side mount the driver side mounts like to break on ek swaps i dented my hood because of it. the profab can be found on inlinefour.com and i highly recommened getting the wire harness looks alot cleaner.
Old Mar 21, 2006 | 04:14 AM
when i say rear mount im talking about the bracket from the motor to the rear motor monut the stock gs-r one is to long and will push the motor forward
Old Mar 21, 2006 | 12:33 PM
Default Re: confirm everything i need to put a GSR B18c in a EK civic (erasable180)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erasable180 &raquo;</TD></TR><TR><TD CLASS="quote">the mounts, axles, and shift linkages are indeed different. you dont have to get an ex harness you can wire into your existing harness. axles $50 ea, mounts, linkage not too sure about, but definitely a little more.</TD></TR></TABLE>
great! thanks for the info.
Old Mar 21, 2006 | 12:34 PM
Default Re: (strokedb16delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strokedb16delsol &raquo;</TD></TR><TR><TD CLASS="quote">when i say rear mount im talking about the bracket from the motor to the rear motor monut the stock gs-r one is to long and will push the motor forward</TD></TR></TABLE>
haha yea i dont want my hood dented. thanks for the tip. i do remember my buddy had to get a rear motor mount cuz it didnt quite fit right. thanks.
Old May 8, 2006 | 05:43 PM
Civic168's Avatar
Default Re: (silenttones)
what about the radiator and fuel pump would that hold up from a EK?
and would you need a new engine side harness if the civic was an EM1?
thanks peoples
Old May 8, 2006 | 05:50 PM
Syndacate's Avatar
Default Re: (Civic168)
not sure about the rad, but the fuel pumps are different, u will need the one for the GSR (I think it might be universal for all B18's..but whatever)
Bloody Hatch
Jun 28, 2012 01:39 AM
4serioferio
21
Jan 29, 2010 01:33 PM
sk8board{Pete}
25
Oct 2, 2007 10:06 PM
mr 636
Feb 26, 2006 09:05 PM
CHAMPwhteEK
15
Oct 20, 2004 01:15 PM
