how do i wire a sunpro mini tach to my hatch
i have 93 honda civic hatch single cam non-vtec (d15b7) i want to install this tach on for now until i get my jdm cluster this is a sunpro mini tach i have it half wired i just dont know where to wire my rpm signal (green) wire. my freind said to the negative end of the igniton coil but dont know wat wire it is if yall can tell me were to correctly wire it and the color of the wire that would help out alot Thanks in advance
ground (black)-to my chassis
power (red)-to my fuse box
lighting (white)-to my dimmer switch
rpm signal (green)- i dont know where
Re: how do i wire a sunpro mini tach to my hatch (eg six)
really should wire the light to the fuse box also.
(not my pic)
where it is circled thats +
one if for constant. one is ffor when lights are on and etc. just test it and u will find the right one.
now rpm just tap the blue wire behind the cluster one the left side. that wire would go into your stock tach if you have one
(not my pic)
Re: (eg six)
your green wire goes directly to the blue wire on the driver side front behind the strut tower. its a BLUE WIRE that has a black rubber plug on it that goes to nothing. thats ur TACH lead. search and youll get the same thing. black n red goes to negative/ground and positive 12v wire or ur battery.
Re: (eg six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg six »</TD></TR><TR><TD CLASS="quote">thanks anyone else know wat wire it would be from my distibutor</TD></TR></TABLE>
its a BIG blue wire solid color
Re: (eg six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg six »</TD></TR><TR><TD CLASS="quote">thanks spnfedeh finally i can install it</TD></TR></TABLE>
