how much boost/HP can stock injectors support?
hey guys......
just curious as to how much power/boost you can run off the stock 240cc fuel injector? if you max out the duty cycle (or close to max) and raise the fuel pressure up high enough along with a walbro 255lph HP fuel pump.
I'm only asking because i need to send my 750's back to RC and in the meantime I'm running the stock injectors. i wont be pushing the car hard at all while i wait but in just curious as to how much power they can actually support....
if i crank the fuel pressure up high enough and tune them to dump as much as possible could they handle 7psi of boost? or roughly 250-270hp?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">stock 240s will max out at like 220-230...</TD></TR></TABLE>
with that being said i think i will put in a boost cut and not push the engine hard until i get my 750's back.
thanks guys.
thanks guys.
wc
Aug 9, 2003 12:40 PM
