engine swap estimates plz. thank you!!
ok all in all i think im either going for a b16 or a b18c1. i know how i have to replace axles, belts, wires, ecu, tranny, clutch,etc. but after everything is installed said and done how much do u think everything will cost? (thats after installation and everything else). thx for any help
Hey, what's up man.......
Utilize the search function in the top right hand corner of your screen. This topic has been covered many of times. If you are having trouble using the search function, or you don't know how to, just reply asking for help, I'll be happy to.
Type in Engine Swap to the search box once you've reached the page.
Well it depends on how much the shop's hourly charge is, I swapped a ls/vtec into a ex civic and well after the motor $4350, and everything else it was about 1,000 in labor. So it really depends on their rates. Where are you located.
Swaps:
https://honda-tech.com/zerothread?id=878010 Swaps Available For Civics
https://honda-tech.com/zerothread?id=50010 Places People Got Their Swaps
https://honda-tech.com/zerothread?id=434668 H22 Axle Information
https://honda-tech.com/zerothread?id=362984 H22A General Information
https://honda-tech.com/zerothread?id=362984 H22 Swap, Rumors or Truth?
https://honda-tech.com/zerothread?id=650329 H22 Info
https://honda-tech.com/zerothread?id=550976 Swapping in a B Series
https://honda-tech.com/zerothread?id=856396 B18C1 into EG
https://honda-tech.com/zerothread?id=635782 ITR Swap into 92-95 VX
https://honda-tech.com/zerothread?id=131949 How To Swap a Motor
https://honda-tech.com/zerothread?id=626892 H22 vs. B18C5
https://honda-tech.com/zerothread?id=528602 B16 vs B18
https://honda-tech.com/zerothread?id=359189 B16 vs B18
https://honda-tech.com/zerothread?id=216389 B16 vs B18
https://honda-tech.com/zerothread?id=163450 B16 vs B18
https://honda-tech.com/zerothread?id=447623 B20 into EK
https://honda-tech.com/zerothread?id=504321 B20 into EK
https://honda-tech.com/zerothread?id=508054 B20 into EG
https://honda-tech.com/zerothread?id=466327 Removing Engine Without Hoist
Forced Induction:
https://honda-tech.com/zerothread?id=544653 Edelbrock Turbo
https://honda-tech.com/zerothread?id=377208 Oil Lines on Firewall
https://honda-tech.com/zerothread?id=635014 Turbo Kit Install
https://honda-tech.com/zerothread?id=517274 Resistor Box
Forced Induction:
