Need a few swap questions answered. harness/sensors, axles, mounts etc!
Old Mar 19, 2006 | 04:21 PM
strictly.business's Avatar
Banned
Default Need a few swap questions answered. harness/sensors, axles, mounts etc!
im swapping in a b16 obd1 motor into my 96 coupe. i was told i can use the stock mounts, except for the back one? i was told it needs to come out of a 94+ integra?
my second question is, what axles will i need? if i order from hmotorsonline and get the complete swap it says it comes with axles which im pretty sure are b16/si axles..will these work?
third question, im going to use my stock harness and use a obd1 to obd2 conversion harness. what sensors..or which plugs will be left unconnected on the new motor? i need to make sure the cel doesnt come on and that it will pass emissions. so what additional wiring other than plug and play will i have to do?
the fourth is, what about radiator hoses? i was told i can use the stock top one but use a del sol dual core lower? what year if this is true?
if anyone has any other comments about things im going to run into that i havent covered let me know please! thanks a lot guys.
Old Mar 19, 2006 | 04:52 PM
Banned
ttt.
Old Mar 19, 2006 | 07:04 PM
Banned
bump..come on guys. i need help.
Banned
up.
Old Mar 19, 2006 | 07:27 PM
Banned
up....wow, i know someone on h-t knows these answers. also, what do i do about the distributor? will my ob2 harness plug into the obd1 b16 dizzy?
Old Mar 19, 2006 | 08:07 PM
hatchi's Avatar
Default Re: Need a few swap questions answered. harness/sensors, axles, mounts etc! (strictly.business)
you will need 99-00 si rear T bracket. reuse the 2 top mounts from your car, use the front a/c bracket and front tranny bracket from any b series motor 94-00.
reuse your wiring harness rewire inj. harness to run obd1 injectors or buy some obd2 injectors plug n play.
repin dist to obd2a plugs or buy obd2 dist
repin alternator to fit obd2a plugs or buy obd2 alternator
you can use delsol dohc hoses.
you will need obd2a to obd1 conversion harness to run the p30 ecu.
This swap is not smog legal in california. i would suggest you get a 99-00 si b16 motor
Old Mar 19, 2006 | 08:36 PM
Banned
well im in az so i should be alright. are there any write ups on how to repin the dizzy and alt? and can i use my y8 injectors? do i need top and bottom hoses? thanks bro.
Banned
also, what about the sensors? which connectors will be left unplugged on my obd2 harness? will i have any cel codes if everything is done right?
Old Mar 19, 2006 | 08:53 PM
Banned
well ****, up. i need this **** answered.
Old Mar 19, 2006 | 09:18 PM
Banned
up
Old Mar 20, 2006 | 03:57 AM
pythoner's Avatar
you can't use your y8 injectors, and don't go posting all over the forum to get your ish answered
Old Mar 20, 2006 | 08:25 AM
Banned
d series and b series injectors are the same...i dont see why i cant. up
Old Mar 20, 2006 | 01:41 PM
ABK's Avatar
ABK
Default Re: (strictly.business)
these people are complete idiots, you can use y8 injectors as long as you use obdII injector plugs.
You need 99-00 si rear mount, y8 tranny mount, 99-00 si block mount (drivers side), use your stock drivers side mount, and all the other mounts are the same. I suggest sticking with y8 harness just extend o2 sensor wires, IAT wires, and some other **** I'm forgetting. You will want to use obdI ecu get a conversion harness.
Use 94-01 integra or 92-00 civic (b series) axles.
And yes you can find all this info if you search. Usually I would just tell you to search but this guys are being ******** and giving the wrong info.
Old Mar 20, 2006 | 05:21 PM
Banned
ok cool but when you say:"99-00 si block mount (drivers side), use your stock drivers side mount" and there are two tranny mounts, one uses bolts, the other uses nuts...would it be better to buy a mount kit? are there any complete mount kits that come with everything i need so i dont have to search for individual mounts? and also, would you recommend hmotorsonline? or another place? where is the iat sensor, or better yet..what does iat stand for? i know these motors back and front, just never done a swap. thanks for the info, and yeah, i have searched and read almost everything in the archive.
Old Mar 20, 2006 | 05:25 PM
Banned
i just realized that its the intake air temperature, which was left out of my intake on my y8..do i need this sensor?
Old Mar 20, 2006 | 06:04 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">ok cool but when you say:"99-00 si block mount (drivers side), use your stock drivers side mount" and there are two tranny mounts, one uses bolts, the other uses nuts...would it be better to buy a mount kit? are there any complete mount kits that come with everything i need so i dont have to search for individual mounts? and also, would you recommend hmotorsonline? or another place? where is the iat sensor, or better yet..what does iat stand for? i know these motors back and front, just never done a swap. thanks for the info, and yeah, i have searched and read almost everything in the archive.</TD></TR></TABLE>
no you need to change the metal mount that bolts into the block behind the timing cover (99-00si). Leave the drivers side mount alone. B series torque mounts (92-00 civic 94-01 integra), those are the ones that bolt up on the bottom infront the engine and tranny. Use your top tranny mount out of y8. And Use 99-00si rear mount.
IAT should be on the b16 Intake matifold that you are swapping in, as opposed to y8 on the intake arm. That's why you might need to extend the wires.
Old Mar 20, 2006 | 06:38 PM
Banned
sick thanks bro. what about the alternator, dist and ps and ac? is there a diragram that shows how to rewire the obd2 plugs or cut and splice the obd1 plugs for the alt, dist?
Old Mar 20, 2006 | 06:41 PM
ABK's Avatar
ABK
https://honda-tech.com/zerothread?id=1472545
Old Mar 20, 2006 | 06:44 PM
Banned
****** stoked homie. thanks.
Old Mar 22, 2006 | 09:34 PM
ChadB's Avatar
I've got one problem that I am running into now. I've been reading about what you said on the trans mount. I have HX and the tranny mount will not bolt up. So do I need one from a B-Series if I am reading this right?
3gcivsedan
Classic Hondas
25
Apr 7, 2009 06:18 PM
jdmstockeg6
Sep 27, 2007 12:10 PM
01typer1124
Nov 1, 2005 09:58 PM
GDM Z28
Feb 13, 2003 02:18 PM
heinvenkin
Jul 14, 2001 09:53 AM
