breaking up in boost
ls/vtec with t3/t4, msd ignition with blaster 2 coil, using wideband o2 sensor, the fuel is a little rich, if i push the gas about a quarter of the way it will build boost and pull, once i press on gas any further it will break up and pop, the plugs are gapped around .042, should they be set lower cause of the boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pilot »</TD></TR><TR><TD CLASS="quote">
For boosted engines, spark plugs gaps are typically 0.022-.028. Gap it down and re-try.
Ross.</TD></TR></TABLE>
yup what he said^
yup what he said^
I have herd of a lot of people having issues with the MSD ignition setup, but that mostly stems from not installing it correctly. So make sure that you installed it correctly and re-gap your spark plugs to about .028. I was running into spark blowout at 7psi with my setup. What kind of AFRs are you running throught your RPM range? That could also be an influence on your breaking up.
good luck
Blaze
good luck
Blaze
