spark plug gap with MSD?
Old Aug 12, 2002 | 10:31 PM
SIK IN DA HED's Avatar
New User
Default spark plug gap with MSD?
ok guys.. finally got MSD. did a search... nothing. i remember people sayin that once u upgrade to a MSD amp... you change your spark plug gap back to stock. is this correct? i just want to make sure before i start screwing around with my new plugs.
im currently running a DRAG3 kit (LS). im usin NGK BCPR7ES11 plugs gapped at .34-.35
also, out of curiosity... would running a larger gap on these plugs and the combination of the MSD/external coil increase engine temperatures (hotter)?
[Modified by dlplayboy, 11:32 PM 8/12/2002]
Old Aug 13, 2002 | 04:10 AM
RGAZ's Avatar
New User
Default Re: spark plug gap with MSD? (dlplayboy)
I am sure I posted MSD gaps before.
MSD + NA = 0.50 gap
MSD + boost under 8 psi = stock gap
MSD + boost over 8 psi = 0.34 max
Best bet is to keep increasing the gap slightly until you start to get high boost misses, then back it down a hair. The MSD will not effect engine temperature.
Good job on the plugs, keep the 7 series unless you are running no intercooler, then think about 8 series.
Randy
Old Aug 13, 2002 | 02:43 PM
New User
Default Re: spark plug gap with MSD? (RGAZ)
thanks!
hondaeg8
Dec 8, 2004 08:18 PM
BLKCRX
Jan 15, 2003 07:51 PM
