How to fix ecu error codes 20 and 22?
Old Mar 16, 2006 | 09:42 PM
fuckaBitch16's Avatar
* B A N N E D *
Default How to fix ecu error codes 20 and 22?
I just put a h22a in a 94 accord. Its showing codes 20, electrical load detector, and 22, vtec pressure valve. I have no idea what these could be or where to start looking to fix the problems. If anyone knows or could help out I'd appreciate it a lot. Thanks.
Old Mar 17, 2006 | 04:08 AM
JimBlake's Avatar
Default Re: How to fix ecu error codes 20 and 22? (B20ZvtecDA)
The ELD is built into the underhood fuse box. Check the circuit to this, but if the ELD itself is bad you gotta buy a new fusebox.
The VTEC oil pressure switch is on the side of the VTEC spool valve. I think it usually has a green plastic plug on the wiring harness. That code can be caused by low oil pressure, it doesn't automatically mean the pressure switch is bad.
Old Mar 17, 2006 | 05:35 PM
dahoopdahup's Avatar
B20Z eh?? Im gonna have the fastest DA in Tacoma!!!! Dont blow your welds...
Old Mar 22, 2006 | 12:23 PM
* B A N N E D *
Alright thanks. But I checked the oil level and its full, and I also changed the pressure switch. I reset the ecu and it still shows the code. I cant figure out where else the problem could be. Any more suggestions would help, thanks.
Old Mar 22, 2006 | 02:21 PM
I asked some people and theyre Vtec wires on there F motors are Blue and Black/Red. Its poss we might have the wrong plug. I will putt my munahh on that buddah.
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
fw190bvi
Jul 23, 2009 03:17 PM
missionaryrider
Dec 9, 2007 01:50 AM
hellogsr
Oct 11, 2006 09:29 AM
lshatch92
Mar 27, 2006 10:04 AM
