check engine light help pleaseeeee....
Old Mar 14, 2006 | 03:53 PM
hatchonarun's Avatar
Default NEED HELP ABOUT CHECK ENGINE LIGHT PLEASEEEE....
i got a 96 civic hatchback with a gsr block and b16 head and an obd 1 p72 ecu... recently after driving it for like 5-10 mins my check engine light comes on but the car is still driving fine also when i turn the engine off then start it back up light goes off then when driving it again it turns back on... this is really gettin to me n i dont knoe what to do if someone can help me out pleaseeee....
Modified by hatchonarun at 7:31 PM 3/14/2006
Old Mar 14, 2006 | 06:47 PM
Default Re: NEED HELP ABOUT CHECK ENGINE LIGHT PLEASEEEE.... (hatchonarun)
someone HELP me...
Old Mar 14, 2006 | 06:49 PM
IMALLSLO's Avatar
Sounds like a knock sensor. Jump the CEL self diagnostic wires and report blinks.
Old Mar 15, 2006 | 10:37 AM
its 23 is it the knock sensor?
Old Mar 15, 2006 | 10:43 AM
j spec's Avatar
Default Re: (hatchonarun)
23 is knock sensor. its at the top of the block above the oil filter directly below the head. should have a green connector and 90% they are all interchangeable. you may have to wire it in if you have not done so its only one wire.
Old Mar 15, 2006 | 10:54 AM
Default Re: (roma's h22eg6)
thanks man i found it and i got one for a b16 ones.... what are the steps to take it off or do i just unscrew it or drain anything?
Old Mar 15, 2006 | 10:57 AM
j spec's Avatar
nothing to drain just unscrew it and put the other one in and plug it up.
Old Mar 15, 2006 | 11:07 AM
ohh iite but they told me to drain the coolant then unplug it... is it true
StewdaddySiRII
Oct 17, 2004 06:58 AM
90Ntegra
Dec 13, 2003 03:55 PM
vtecman
13
May 13, 2003 12:41 AM
PhuckinHondas
Sep 18, 2002 09:37 PM
