Turbo ITR Problems
Turbo ITR
10:1 JE pistons
Eagle Rods
Drag 3 bolt on kit
Heres the problem, motor HITS vtec, can hear it audibly, 70psi of oil pressure AFTER the vtec solenoid so there enough pressure. Solenoid is working properly, not clogged or anything. Car holds boost , no boost leaks (9psi)
Car hits vtec and falls on its face. This is a brand new Honda head, that the customer had smoeone else assemble it. Im thinking the rocker arms are only engaging on certain cylinders. only thing i can think of.
10:1 JE pistons
Eagle Rods
Drag 3 bolt on kit
I had a similar problem with a car, and the intake cam was retarded a good bit. That is all I can say from a personal experience. Hopefully it is something dumb like that and not internal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR »</TD></TR><TR><TD CLASS="quote">You definately have a problem if that is your dyno graph</TD></TR></TABLE>
Isn't that why he posted here?
whats the compression test results?
i would assume the car drives and idles fine....all is well...then once you hit vtec it feels like a turd? does it break up and buck and sputter and ****....or just not make any power...sometimes the graphs dont completley resemble how the car "feels" on the dyno
mine dod the same thing, as far as power, intake cam was reatrded 10 degrees. cam gear bolts slipped.
i know you said you checked the cam timing. but i would definetley re time the car with a good light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">mine dod the same thing, as far as power, intake cam was reatrded 10 degrees. cam gear bolts slipped.
i know you said you checked the cam timing. but i would definetley re time the car with a good light</TD></TR></TABLE>
That was exactly what I thought the first time I looked at the graph.. I had a car that was retarded like 5-6 degrees on the intake and it did the same thing..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">whats the compression test results?
i would assume the car drives and idles fine....all is well...then once you hit vtec it feels like a turd? does it break up and buck and sputter and ****....or just not make any power...sometimes the graphs dont completley resemble how the car "feels" on the dyno</TD></TR></TABLE>
Compression was 200-200-200-200
Plugs are gapped accordingly, no blow by, no smoke, no burning oil. car idles fine, timing belt and cam timing is dead on the money, reset it twice just to be sure.
car drives fine until vtec then falls on its face. the customer , as i said, bought this head brand new dissasmbled from honda. im thinking some of the rocker pins are missing in the head, im gonna pull the cams out tomrrow
take off the valve cover and look at the cams. Make sure the vtec lobes arent ground down or screwed up...
look at the middle rocker arms and make sure each one has the pin installed inside of it.
you may have to take off the cam caps and see if the oil restrictors are there
can you put an oil pressure gauge on the motor.....ive seen them go into vtec and as they rev fall back out due to oil pressure....it mechanically will not be in vtec and it will be runnign the vtec map in the ecu and run like ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">can you put an oil pressure gauge on the motor.....ive seen them go into vtec and as they rev fall back out due to oil pressure....it mechanically will not be in vtec and it will be runnign the vtec map in the ecu and run like ****</TD></TR></TABLE>
Just like my damn K20.
ok, here what i did:
Plugged all the holes in the head, ran 100psi of air pressure through the allen key hole in the front of the solenoid.
The rockers lock together, but very loosely, the pins basically slide together, but they dont LOCK
interesting.....
interesting.....
