my DA wont start after new head work done
Old Mar 13, 2006 | 12:49 AM
DAGS-R's Avatar
Default my DA wont start after new head work done
im trying to start my buddies 91 LS after I put on a rebuilt head and new timing belt. The timing is right on the money and did a valve adjustment to the head prior to installing it on the bottom end. .009ex .007 intake. New plugs and wires. I try and turn it over and it doesnt start, i have fuel and spark. after turning it over after a while it begins to want to start and then finally starts for a couple seconds then dies and the whole process begins again. any body have any ideas? no codes are being thrown.
Old Mar 13, 2006 | 01:03 AM
Orangecivic251's Avatar
Default Re: my DA wont start after new head work done (DAGS-R)
and not to be a D!ck but are you positive on the timing? all the way around? including distributor right in the center
Old Mar 13, 2006 | 06:20 AM
solareclipseauto's Avatar
Default Re: my DA wont start after new head work done (OrangeCiviC251)
i would double check the timing
Old Mar 13, 2006 | 08:18 AM
DAGS-R's Avatar
Default Re: my DA wont start after new head work done (solareclipseauto)
Yeah im positive on the timing, cams line up and im at top dead center. dizzy is right in the middle. crank woodruff key is right in the middle when both cams were lined up. thats right, right?
Old Mar 13, 2006 | 11:07 AM
FalkenSiR's Avatar
Try this, unbolt your dizzy and hold it in place. Now have someone crank while you slowly turn the dizzy. See if it starts, just a thought. I've seen that work.
Old Mar 13, 2006 | 01:35 PM
ghg78's Avatar
I NIKES
check the ground wire in the back.by the thermo.
Old Mar 13, 2006 | 01:45 PM
jjdickm's Avatar
Default Re: (ghg78)
timing is 5-10degrees after top dead center. make sure that it is in that spectrum.
Old Mar 13, 2006 | 01:59 PM
advert's Avatar
timing. if you have perfect timing, fuel and spark it would start simple as that. only other thing could be compression
Old Mar 13, 2006 | 02:31 PM
Yambor's Avatar
Default Re: (advert)
run a compression test and leakdown test..
double check timing...use the light...
sunnyutahsky
Aug 10, 2013 06:32 PM
90crxef
Mar 29, 2008 03:15 PM
RenzoDaPlayboi
Nov 3, 2006 10:01 PM
sobe
Feb 26, 2005 12:27 PM
Will_H
Apr 18, 2004 03:49 AM
