Tranny makes noise...
Old Mar 12, 2006 | 05:44 PM
em1 Ziggy's Avatar
Default Tranny makes noise...
anyone one know whats wrong with my car.. i have a b16 tranny. when i step on the clutch i hear this scratching noise.. it sounds like a whirring noise like dry leaves getting crushed. it also makes the noise when engage first gear.. when im in second to 5th gear is fine i don't hear the noise. It sounds worst and the sound is gets louder when i reverse... anyone know what this could be?
Old Mar 12, 2006 | 06:01 PM
CardDealer's Avatar
Banned
Default Re: Tranny makes noise... (em1 Ziggy)
Modified by CardDealer at 2:49 PM 11/16/2006
Old Mar 12, 2006 | 06:10 PM
em1 Ziggy's Avatar
Default Re: Tranny makes noise... (schlit)
only when im pressing the clutch... when my foots off the clutch the noise is gone
Old Mar 12, 2006 | 06:12 PM
em1 Ziggy's Avatar
yes when im depressing i just need some info before i get it to shop so they won't add extra stuff to the diagnose in other words i don't wanna get ripped off anyone know what this could be before i get it checked...
Old Mar 12, 2006 | 07:06 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 2:48 PM 11/16/2006
Old Mar 12, 2006 | 07:20 PM
JDMKid71's Avatar
could be one or maybe more of three bearing.... the throw out bearing (the one on the release fork that actually contacts the pressure plate to release the clutch) The pilot bearing (in the flywheel, but doesn’t make since in this case because it would be heard all the time.) or maybe the main input shaft bearing (this one is actually inside the tranny... the bearing closest to the clutch housing and is known to go bad, however once again it would be heard most of the time. esp. in neutral no matter if the clutch is, or is not engaged....) hopefully this could be some help.
Old Mar 12, 2006 | 07:32 PM
pro1342's Avatar
^ I agree.
Old Mar 12, 2006 | 09:06 PM
em1 Ziggy's Avatar
Default Re: (pro1342)
thanks for the feedback guys.. will replacing my clutch with a new one fix the problem???
Old Mar 13, 2006 | 03:00 AM
CardDealer's Avatar
Banned
Default Re: (em1 Ziggy)
Old Mar 13, 2006 | 09:30 AM
em1 Ziggy's Avatar
Default Re: (schlit)
sounds good!! thanks for the good advice h-tech members!
Old Mar 13, 2006 | 04:17 PM
JDMKid71's Avatar
no prob.. let us know what you did or what the techs at the shop said if you take it someplace...
Old Mar 14, 2006 | 06:32 PM
axtran's Avatar
dang, sounds like i have the same problem in my '92 DX. did a lil reading and now i'm frowning. grr
welp b16 engine trans swap is calling me even louder now..
citrus3000psi
Nov 12, 2007 02:23 PM
CPR
Dec 14, 2005 10:26 PM
david
Nov 7, 2005 09:24 AM
4gnhatch
Jun 24, 2005 06:53 PM
Emshhh
11
Feb 2, 2005 11:10 PM
