hmmmmm wrong timing?
Old Mar 7, 2006 | 06:03 PM
strongarm1731's Avatar
Default hmmmmm wrong timing?
So i was checking the timing on my car today in class (studying to be automotive tech) and the furthest i can advance/retard the dizzy is to 14btdc and 0 btdc. I did cams and cam gears about 2 months ago, and the cars been running fine. The only complaint i have about it is when i rev it into vtec at a standstill, it makes a chattering sound right when vtec engages. This is on a slow rev to 6k. If i just stomp on it, it doesnt chatter.
My adjustable cam gears are set at 0 exhaust and +1 intake. I plan on putting these both to 0 this weekend and seeing if that helps. I just figured it was a bad base map that was making the chatter... but with trying to time the dizzy- i think im off a tooth.
input?
Old Mar 7, 2006 | 06:12 PM
methanemotorworks's Avatar
Default Re: hmmmmm wrong timing? (strongarm1731)
yes your off by a tooth...from your explanation...and its an easy check too...
Old Mar 7, 2006 | 09:05 PM
Default Re: hmmmmm wrong timing? (methanemotorworks)
i will have time to check it sunday, but until then i figured i would try to get some input and a confirmation that is really is off Hopefully im doing no damage... and if i am, then its time to run it till it dies haha
Old Mar 9, 2006 | 08:54 AM
well the valve cover is off, and the belt is lined up perfect. I took pictures incase anyone wants to double check. Could i have gotten the wrong cam gears or something? Im going back out to set the cam gears back to 0 and 0... then ill come back and check the post for ideas
-Don
Old Mar 9, 2006 | 11:02 AM
now im stumped
Put the cam gears back to ZERO. Double checked the alignment of the belt, and its right on the money. I jumped the ecu, and went to time my car- the most it will go is11btdc and 0 (still has room on the dizzy to retard it).
ANY IDEAS?
Old Mar 9, 2006 | 01:01 PM
tha_badguy's Avatar
u cant hit vtec while in neutral....
Old Mar 9, 2006 | 07:35 PM
Default Re: (tha_badguy)
even with a chipped p28? Im getting it retuned soon (boosting), but the sound does happen @ my vtec crossover, and sounds goofy when im at say... 7k and off the gas (decreasing rpm's).
Old Mar 19, 2006 | 07:08 PM
Default Re: (strongarm1731)
no real answers yet. Is it normal?
dbiker207
Jun 9, 2007 09:02 AM
Prelude Styl
Mar 31, 2004 07:20 AM
ismkv8s
Nov 3, 2002 11:27 PM
RexB16
May 10, 2002 10:18 AM
