Code 41 Primary O2 Sensor heater CIRCUIT malfunction!
Old Mar 6, 2006 | 12:01 PM
alleyezonme's Avatar
Default Code 41 Primary O2 Sensor heater CIRCUIT malfunction!
Hey
The first thing i did was swap O2's with one that i think works from a fellow honda-techer. I still have the code though, so i am thinking that maybe it is the wiring that has a short or is not connected. So I am wondering if anyone knows what is on the same circuit as the Primary 02 sensor?? Or should i just buy a brand new O2 sensor and try that?
thanks
Old Mar 6, 2006 | 12:39 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Code 41 Primary O2 Sensor heater CIRCUIT malfunction! (alleyezonme)
Not sure but do you happen to have a swapped CX/VX? And did you convert the 5-wire to 4-wire? Thats why mine threw the code
Old Mar 6, 2006 | 03:59 PM
Default Re: Code 41 Primary O2 Sensor heater CIRCUIT malfunction! (SkoundrelUSA)
it is a 93 jdm h22 in a cx, with a 4 wire O2... do i need a 5 wire?
Old Mar 7, 2006 | 02:26 AM
morning UP
Old Mar 7, 2006 | 11:30 AM
after worker
Old Mar 7, 2006 | 12:33 PM
SVOboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme &raquo;</TD></TR><TR><TD CLASS="quote">it is a 93 jdm h22 in a cx, with a 4 wire O2... do i need a 5 wire?</TD></TR></TABLE>
You don't need a 5 wire, but the cx came wired with a 1 wire so you would need to have wired up the 4 wire or else the ecu won't recognize it.
Old Mar 7, 2006 | 01:04 PM
Default Re: Code 41 Primary O2 Sensor heater CIRCUIT malfunction! (SVOboy)
ok good i did that, so what could be the problem besides just replacing the O2 again?
Old Mar 7, 2006 | 01:10 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme &raquo;</TD></TR><TR><TD CLASS="quote">ok good i did that, so what could be the problem besides just replacing the O2 again?</TD></TR></TABLE>
If your wiring is good and the O2 is good, I would assume the driver (QM3) in your ECU is bad.
Old Mar 8, 2006 | 01:30 PM
Default Re: Code 41 Primary O2 Sensor heater CIRCUIT malfunction! (Jim Truett)
well i get the same code w/ a chipped p28 and a p13. The O2 was used though, do you think a fellow HTer scammed me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I just want to make sure the O2 is all that is on that circuit before i start replacing stuff.
thanks
Old Mar 9, 2006 | 02:18 PM
up like my idle
Old Mar 10, 2006 | 02:36 AM
help rid my car of codes!
Old Mar 10, 2006 | 12:58 PM
i wish 2pac was still alive to slap these fake *** rappers today bump
GSX TO CX
Mar 5, 2005 10:11 AM
EARLdaSQUIRREL
Feb 3, 2005 04:26 PM
alexb16hb
Apr 3, 2004 11:21 AM
Mike D
Apr 1, 2004 11:33 AM
turbotime
Jul 12, 2003 08:06 AM
