ecu code 22 stopping vtec engagement?
Old Mar 6, 2006 | 05:35 AM
ezza's Avatar
Default ecu code 22 stopping vtec engagement?
i have a P72 ECU wich is throwing a code 22 (vtec preasure switch), will this stop my vtec from engaging?
Modified by ezza at 6:58 AM 3/6/2006
Old Mar 6, 2006 | 10:50 AM
mec. pedri's Avatar
Default Re: ecu code 22 stopping vtec engagement? (ezza)
yes--------------code 22 is for vtec pressure. check continuity between plug wire blk/blu and and ecu. also check to see if plug is getting ground. make sure you have the proper oil level.
Old Mar 16, 2006 | 01:27 PM
ezza's Avatar
Default Re: ecu code 22 stopping vtec engagement? (mec. pedri)
mensioning the oil level, will being over the max oil line stop the vtec from engaging? i have a bit over and havnt drained it yet.
Old Mar 16, 2006 | 01:28 PM
ezza's Avatar
plus would too much oil cuase an engine check light?
pureclass69
Mar 14, 2011 03:05 PM
djSALIX
Nov 5, 2010 07:43 AM
gotslicks
Nov 26, 2006 03:44 AM
LSracing94
17
Aug 7, 2006 10:00 AM
allmtrSI
Apr 29, 2003 05:13 AM
