Rear disc problems?
Old Mar 4, 2006 | 04:11 PM
MustangPunk302's Avatar
Default Rear disc problems?
We tried to padslap a '93 EX and we can't get the piston to go back into the cailper, and the praking brake moves the piston out so we know it isn't seized. What's the trick? Any quick help would be great, thanks...
Old Mar 4, 2006 | 04:20 PM
schardbody's Avatar
you do know its a screw in caliper right??? if so, then open the bleeder and try it that way, sometimes the pressure of sending the fluid back through the system is enough to keep it from going in.
Old Mar 4, 2006 | 05:45 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (schardbody)
^ right.
Open the bleeder valve and twist the piston clockwise.
Old Mar 4, 2006 | 07:28 PM
95jeremie's Avatar
Default Re: (Screwtape.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape. &raquo;</TD></TR><TR><TD CLASS="quote">^ right.
Open the bleeder valve and twist the piston clockwise. </TD></TR></TABLE>
that should do it
Old Mar 4, 2006 | 07:31 PM
Everyones Hero's Avatar
Default Re: (95jeremie)
The fronts aren't screw in too, are they? Me and my friend just used those things that you spin and they tighten down to push the piston back in the front.
Old Mar 4, 2006 | 07:35 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
What you did for the front is fine.
Old Mar 4, 2006 | 07:52 PM
95jeremie's Avatar
Default Re: (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">The fronts aren't screw in too, are they? Me and my friend just used those things that you spin and they tighten down to push the piston back in the front.</TD></TR></TABLE>
A C-Clamp that is what i use and never had a problem
Old Mar 5, 2006 | 06:23 AM
schardbody's Avatar
just the rear are screw in.
Morasso
Mar 20, 2008 05:12 PM
^LORTA^RACING
29
Dec 13, 2007 03:52 PM
ap1_driver
Honda S2000
Oct 17, 2006 10:27 AM
GReddy SI
Aug 15, 2004 04:03 PM
crxcess
Oct 9, 2002 10:50 AM
